#1131 |
Bob, thats exactly what Atech claimed "it may have been a return". I've just never seen bearings loosely packaged like that before.
Todd Greene |
#1132 |
I'll see if they're still at the shop and check, may have gone back already.
Todd Greene |
#1133 | |
Liked 973 Times in 310 Posts
#1134 |
Liked 372 Times in 129 Posts
Simple case of a set Clevite H series bearing out of their original packaging, lets move on to flow numbers and dyno data, and finally track testing data. If you have instant oil to the top of the engine at the hit of pre lubing, thats something you better fix.
#1135 |
Lesson learned.
Todd Greene |
#1136 |
Sorry I been neglecting all this but that pesk job has really been getting in the way! Oh look, bearings in proper packaging!
Todd Greene |
#1137 |
VP C-12 is the DEVIL! Heads are rusted like crazy, had to pound some of the exhaust valves off the seat, real bad. Little work on the heads today, going to throw everthing in the washer next week.
Todd Greene |
#1138 |
Liked 648 Times in 193 Posts
#1139 |
Liked 705 Times in 219 Posts
Every time I shut my cars down for any length of time after using C-12, I fog the motor. That means to fire it up, open the throttle with the engine running and put a couple ounces of Marvel Mystery Oil or even plain old ATF down the carb. When a puff of smoke appears out the headers,shut it off. The oily film prevents rust from appearing on the valve faces and seats and the cylinder walls. C-12 is a very dry fuel and it leaves metal surfaces unprotected from humidity in the atmosphere causing rust. I imagine Florida has more than its share of humidity year round.
#1140 |
Liked 5 Times in 3 Posts
C11 is faster, fog motor with WD-40 after engine cools down use starter button open throttle blades crank it over for about 10 seconds works good in Florida.
