Old 05-05-2019, 11:05 PM   #31
pfordamx
Liked 7 Times in 5 Posts
Default Re: AMC Stocker suggestions
unless its changed this year due to some factoring the 1970 360 4bl is a really good Super stock combination currently with only a 260hp rating i know a couple of people who are building this combo.
pfordamx is offline   Reply With Quote
Old 05-05-2019, 11:39 PM   #32
Originally Posted by typhoon View Post
Thanks again . Not giving up on AMC but I'm going to enter into bracket racing to start. found an S10 cheap only needs motor. I have an AMC at home but cannot be used for stock racing,it'll just be a cruiser. I have found a 74 hornet wagon 232 6cyl. The way I read the chart, rating factor is 19.33 T/SA ?? 14.40 et. i would have to get around 200HP to achieve this . I think could be done. but you need to make car run up 1 second under index to be competitive ? the car can easily become a 304 or 360 as well. so I guess i have to move to another section for bracket advice.
thanks again Gentlemen
I did read a good quote " Enjoy the ride there is no return ticket" George Carlin.
Pay attention here.. 232, 1v? No.... 258, 2v..Yes..Only way to go here, with your budget.
74 -77 Hornet ..Looks the same to me. Nobody knows. Nobody cares.
Several guys here are very familiar with this combo.You already got the basic blueprint.
Go..
Old 05-08-2019, 07:29 AM   #33
HP HUNTER
Liked 373 Times in 129 Posts
Dwight pointed out some facts on a 1970 360 combination in stock, I was surprised. Should make great power.
1. Big Bore
2. Good amount of lift
3. Lots of head flow
Old 05-08-2019, 08:56 AM   #34
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Go..
Mark is correct , the '77 258 IS the best reasonably low dollar combination to build .
I've got quite a bit of experience with all the AMC combos,but the '77 258 is a very affordable build that ran run well without high dollar converters or transmissions or suspensions.
The BBD 2bbl carb is very workable , the cam and blueprint specs are very favorable.
A smart builder can run more than a couple tenth's under the index with cast Badger pistons , $100 rings ,stock rods and without doing anything to the head but the valvejob.
The 232 1 bbl combination is a looser dont waste time or money .
Old 05-17-2019, 01:53 PM   #35
pfordamx
What do you guys thank about a 79 2 door concord with a 258 2bl and a 904 torqueflight asking because we have the car and alot of the basic pieces to get it going.
Old 05-17-2019, 06:25 PM   #36
It's okay ..Makes U/SA , which is still a V8 class. Not enough heads-up around to worry about though. All the previous details still apply.
Old 05-17-2019, 06:42 PM   #37
pfordamx
14.85 doesn't seem like it would be too terribly hard to hit. could be underestimating the task though.
Old 05-17-2019, 07:38 PM   #38
You have to be able to run that in the middle of summer. You don't want to leave too much on the table due to budget constraints.
Not fun , nor economical to have to worry about running the index all the time.
Old 05-17-2019, 08:10 PM   #39
jmantle
Liked 172 Times in 81 Posts
I've run 13.90's at U weight in good air, .600 under is not hard to do with a 258 2 bbl 77 or 79 trim in U. I think the 79 pistons more than make up for losing .008 in cam lift.
Ideally find something heavy enough to run V.
Jim Mantle 6632 V/SA
jmantle is offline   Reply With Quote
Old 05-18-2019, 11:17 AM   #40
pfordamx
didn't there used to be a cam lift rule that allowed all cars under x amount of lift to go use x amount of lift.
