#1251 |
Liked 355 Times in 136 Posts
Wow! Todd, if there ever was a mulligan for letting a car like that get way, that would be it.
#1252 |
Ordered some parts this week, Hardblok, Racepak stuff, head gaskets, main studs, head bolts and a crankshaft. Pretty sure I wont get the block tomorrow but I'll call to check just in case.
Todd Greene |
#1253 | |
Liked 372 Times in 129 Posts
I know of at least one S/S that runs extremely well with a production block, its all about the core and the prep. Last edited by HP HUNTER; 06-06-2019 at 11:46 PM. |
#1254 |
Not sure if I have the right one and not sure if I'm doing it right but I'm doing it. The learning curve... it is steep.
Todd Greene |
#1255 | |
Liked 1,436 Times in 299 Posts
I think the key is that it hasn’t been bored bigger. We even coated the Pistons to help the sizing over time. We had a 327 once that we filled and ran .060 over. My preference to to not run a filled block if I can avoid it. Either a thick enough stocker or an aftermarket
James Schaechter 3163 STK |
#1256 |
Made a new "wavy washer" today and got the Racepak bulkhead in, made some templates for brackets, moved some carpet for cables and made a new hole for the switch panel ribbon cable, looked like crap running across the firewall.
Todd Greene |
#1257 |
I didn't get much accomplished this weekend, dragging my rear. Sunday I worked on the trans. getting the Racepak stuff started.
Todd Greene Last edited by Nmbr1GMfan; 06-10-2019 at 09:26 AM. |
#1258 |
Liked 10,762 Times in 2,237 Posts
Will the Race Pac be affected being that close to the coil? Car is looking good!
#1259 |
Racepak said as long as the box isn't near it should be good so I hope not.
Todd Greene |
#1260 |
Parts. And these bearings didn't come loose in a carboard box.
Todd Greene |
