My drag pak has a manual rack in it
Anyone switch there’s back to a electric power rack and what pump did u use The stock challenger or go with a after market pump Thanks |
Liked 802 Times in 339 Posts
Check with Jeff Teuton, he has done this. I think there is a thread here about it.
I did a search but didn’t find anything
Liked 66 Times in 31 Posts
I would leave the manual rack in it and put and electric column out of a Toyota in it. You'll also need the P/S ECU.
Pretty sure I found the problem
The stock joint out of the column is starting to twist and binding up and has really tight spots as it’s wobbling as I turn it Time to tool up a new column for it |
Liked 23 Times in 8 Posts
The early Drag Pak Challenger (LC Platform) use the column with the articulating joint and a production rack & pinion with no power valving installed. This steering rack has a stock ratio and requires lots of input effort so it's hard to steer. The later Drag Pak cars (LA Platform) use a steering column with a typical slip shaft instead of the articulating joint. Flaming River makes a replacement rack & pinion PN FR1515MPR16 which requires a fabricated steering intermediate shaft which adapts the LA column to the Flaming River rack. This is the setup which all of the latest Drag Paks were built with and solve all of the issues with the setup that came on the LC platform cars.
Liked 44 Times in 20 Posts
If you want a simple electric steering conversion, use this....
http://www.dcemotorsport.com/Home/EPAS#Microsteer |
#9 | |
Liked 704 Times in 281 Posts
Mine has the mopar 5155176 rack
