Liked 800 Times in 237 Posts
In general, what's the guideline for finished journal sizes on a .013 stroked stocker crank?
Can one that's .010 and not stroked finish at .020? Thanks! -Al
"That'll never work....." |
Liked 11,002 Times in 2,263 Posts
It all depends on a few things. Is the stroke on long side or short side of spec. How close is the index, 90*, 90*, 90*, 90*. The size of crankpin. We have made a +.013 crank and it be 10/10.
Liked 397 Times in 153 Posts
No, one that's already .010 would finish at .030. You can't take .013 off one side of the throw when there's only .010 to offset grind with.
Phil Molski PMR Performance S/C 1623 |
Liked 314 Times in 177 Posts
#5 | |
If you take .010 off ONE side, you've moved the centerline .005, increasing the stroke by .010.
If you grind .0065 off one side, where do you remove the remaining .0035? bearings usually come in undersizes of .010, with plus or minus .001 You need to move the centerline .0065 to achieve .013 offset
Phil Molski PMR Performance S/C 1623 Last edited by pmrphil; 06-20-2019 at 08:21 PM. |
The center-line of the crank pin is moved .0065 away from center-line of mains. If stroke on stock crank is 3.483'' instead 3.480'' and the pin is on the high side of tolerance it will make a stroke of 3.493'' grinding it .010'' under to the low side. But usually it takes a .030'' under on the rods to get .013'' stroke. If the index is good why not make it .014'' long?
Liked 804 Times in 168 Posts
Larry has it correct , it is a math exercise. The one thing that you also must realize is that indexing can not be fixed much by grinding. As an example, a 3" stroke crank would take a move of .026 for each degree it is off. to move it that much, it would need to be ground a minimum of .052 under.
Dave Casey 1330 STK |
Liked 3 Times in 2 Posts
Would you then have the rod journals chrome plated to build back to a std bearing? Or some other method. And would it be worth offsetting to a shorter stroke, if allowable to gain piston to valve clearance so as not to sink the valve job,in a piston without valve reliefs?
Liked 1,032 Times in 283 Posts
I never heard of anyone hard chroming a crankshaft to bring up a surface thickness. I thought it was like nitriding, to give a harder surface so the bearings doesn't bite into the journal.
Duane Hoven 1342 SS/GT Last edited by 1347; 06-22-2019 at 12:58 PM. |
