Old 06-20-2019, 04:41 PM   #1
Fred D Bartoli
Default Exhaust Gaskets
Can anyone recommend a set of exhaust gaskets that work on a small block Chevy with hooker adapter plates.? Tried several over the years haven't found anything that doesn't leak.
Thanks
Fred D Bartoli is offline   Reply With Quote
Old 06-20-2019, 05:46 PM   #2
pmrphil
Liked 397 Times in 153 Posts
Default Re: Exhaust Gaskets
Remflex. They won't leak.
Phil Molski
PMR Performance
S/C 1623
Old 06-20-2019, 08:03 PM   #3
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Fred, you will not be disappointed with Remflex!
Dave Turner
SS/GT #1153
Old 06-21-2019, 09:37 AM   #4
monte385
Liked 27 Times in 19 Posts
If you have good flat flanges, Hi Temp silicone works great.
monte385 is offline   Reply With Quote
Old 06-21-2019, 10:48 AM   #5
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Fred, if you’re talking about between the adapter and the head, I don’t use a gasket and have had zero problems. Just lightly butter it with red rtv and bolt the plate onto the head with no gasket.
For between the plates and the header flange I really haven’t had a problem with mr gasket typical gaskets. BUT I have learned after you first fire up the engine and get em hot for the first tine, come back and snug up on the header bolts. You’ll typically find em a bit loose and if you don’t snug em, after a dozen passes they’ll leak out and burn up.
Old 06-22-2019, 11:20 AM   #6
Jeff Niceswanger
Liked 1,058 Times in 376 Posts
We made our own. And have been using the same identical gaskets for over a decade. Must have been on and off 50 times. No leaks what so ever. I have to give brother John the credit. He found this material that they used where he worked. ( Gore-Tex) They used it in the boiler rooms. We just took a small sheet of it, found a gasket we liked and fit, and copied at a cad table with a knife blade on it. I know why nobody sells them, you would never sell a second set !
This is a second set we cut out by hand but have not needed …...
Jeff Niceswanger 3740 SS
Old 06-22-2019, 08:09 PM   #7
Ron Miller
Liked 13 Times in 7 Posts
Jeff,
Thanks for the info. I let my Fingers do the walking on the net. I might have found a supplier near me in AnnArbor, Mi.
Thanks Again,
Ron Miller is offline   Reply With Quote
Old 06-22-2019, 10:16 PM   #8
Fred D Bartoli
Jeff,
Thanks they have it at Mc Master Carr.
Old 06-22-2019, 10:31 PM   #9
MR DERBY CITY
Liked 8,212 Times in 1,536 Posts
Amen, haven’t used exhaust gaskets in years.....
Old 06-22-2019, 11:05 PM   #10
Jeff Niceswanger
Silicone is a mess. And you have to clean it off every time you take them apart MJ. Call me lazy but I like using reusable gaskets that seal as good as silicone without all the disadvantages ..
