#11 |
Liked 133 Times in 76 Posts
Power to what switch?
#12 |
Liked 93 Times in 52 Posts
From the trans brake switch
#13 |
Liked 341 Times in 67 Posts
#14 |
As stated above it's not legal if that is an issue. Then I wonder what the theory is of using a relay. The 2 step obviously doesn't use much power. Generally controlling the transbrake solenoid with a relay isn't done or needed. Don't see what good a relay is going to do. Still think you have a bad connection somewhere.
#15 |
Liked 320 Times in 102 Posts
Are we talking about a stocker with a brake pressure switch????
or A super stocker with a transbrake button???? I'm confused?????
#16 |
Liked 2 Times in 2 Posts
Friend of mine had the same problem on a stick car with a 7AL 2. We would only only change the 2 step launch like 200 rpms and it changed like 800-1000 rpms when he actually put it on the two step. Its the diff switches that are the problem. A lot of guys have the same problem. He switched to The Grid. Problem solved.
Scott Chalk 1226 I/SA |
