#1381 | |
Walt, it's so cool that a project I share with my kid can bring back a positive memory from your childhood. I really enjoyed reading that.
Todd Greene |
#1382 |
We have parts ordered! Re-ordered the same crankshaft and set of rods, both seemed well machined and very consistent for parts on the cheaper end of the scale. Also ordered a new Dart block, the SHP version, if we're lucky maybe we'll get some parts this week. Boxed up some pistons and next dayed them back to Diamond so might hear something on that tomorrow then we'll get a new set in the works. I also took a couple rods out and pulled a main just to check the bearings to verify we did have a healthy one.
![]() ![]() ![]() And this is one of my favorite carnage pics! ![]()
Todd Greene |
#1383 |
Liked 450 Times in 133 Posts
Wow it beat itself up pretty bad, you and your daughter hang in there its worth it in the end when you take that win light ! I think we all have been through this just don't get discouraged .
Jerry Retired 3490 3492 Stk SS SST |
#1384 |
Liked 18 Times in 12 Posts
Those are some great pictures Todd
![]() Through your disassembly where you able to discover anything that could be a clue to the failure? Glenn
"Real Race Cars Have Tailgates" |
#1385 |
Glenn, We know exactly what happened, why it happened is a bit of a mystery but we did send a few parts out to be examined that I hope will clear it up. We really need to know exactly why, so it doesn't happen again.
Todd Greene |
#1386 |
Liked 251 Times in 125 Posts
The car I was a partner on only ran a couple of tenths under. We still had fun. The biggest problem we had was a cam that wiped a lobe. We "only" had to disassemble, clean, and reassemble. (And of course, be comfortable that we were sure why it wiped the cam.) You're dealing with, and handling a lot more. Very safely, for certain, of course. :-)
#1387 | |
Todd Greene |
#1388 |
I should've made the point that even though we were only a couple tenths under (mostly because funds were limited), as others have said, we enjoyed working on it.
We built for a class that wasn't overly populated in our division, and also built a car that was capable of moving to different classes if the class got faster than our wallet thickness. lol We weren't there to set records, for sure, be we were able to go rounds on occasion. Bottom line: What you both are going through is part of the fun, even though it can be really hard to see at times! Nothing worth while is easy. Cliche', but true. |
#1389 |
Liked 650 Times in 194 Posts
Todd pm sent.
#1390 |
Todd, Do you have a pic of the other five pistons?
