#231 |
Liked 242 Times in 81 Posts
Back to the Pink Lady to gather some points?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
#232 |
Ten LODRS events left this year. Plenty of opportunities.
#233 |
Did Patsy break her camera? Where are all the pics?
#234 |
Liked 335 Times in 182 Posts
Years ago when we had porosity problems while running aluminum Oldsmobile small block heads in Modified we encountered weeping or sweating-- our solution was to use either Alumaseal the powdered stuff or something called "Water Glass" or sometimes called "Sodium Silicate" I think is the actual name for it--we got that stuff from a Pharmacy !! The farmers used that stuff on chicken eggs before refrigeration and would dip the egg into and could leave it on the kitchen counter for a few weeks and the eggs would not spoil---Not sure how bad your situation is but both methods either separately or together solved our problem. BUT before you go into tearing it all apart you might give it a try. Good luck interesting build have been following it and wish you well
#235 |
Liked 10,964 Times in 2,260 Posts
After Rockingham I should be able to make some progress on "Dumbo''. Plan of attack is put on rack, drop oil pan, fill and pressurize cooling system, and determine the source of leak. Remove engine, disassemble, inspect, repair, hone cylinders, assemble, dyno, install, sort out car, go to the Gators.
That should keep me busy for a few days. |
#236 | |
Liked 364 Times in 138 Posts
Dave Turner SS/GT #1153 |
#237 |
Larry and Patsy,
Thank you for the joy you bring to this forum for all the right reasons. Sincerely, Frank |
#238 |
Fighting getting the pan off in the car. I don't want to remove center of cross member. If anyone has removed center tube on Drag Pack let me know. Removing trans and CSR shield, that Ray Charles could see that does not fit without modification. I'm going to try something else.
#239 |
Thanks Peter.
Got the pan off and no rust on crank or rods, I would rather be lucky than good. Filled cooling system with water and pressurized system to 25 psi. Raised the car up, got a comfortable chair, blue paper towels, a strong lite, and waited. Waited some more and not a drop was leaking, but in the bottom of the oil pan was the tell tale greenish brown milkshake of water and oil. It always puts me in my place when a piece of metal is smarter than I am. Now to remove engine and check the top end for leaks. I just knew that when I went to drain the odd bank of cylinders water jacket and nothing came out I had found the problem. Not so |
#240 |
Liked 397 Times in 153 Posts
Well, maybe not found it (yet) but you did locate the issue. I would think somewhere in the block, though, if it was a top end leak there still should have been some water left in the block
![]() Are you going to have the block pressure tested while it's out?
Phil Molski PMR Performance S/C 1623 |
