#1611 | |
Todd Greene |
#1612 |
Liked 510 Times in 117 Posts
Hey Todd. Watched the in car video and Autumn did everything right including the burnout. The burnout you can do in 2nd or 3rd. Doesn't matter. I've made enough runs on mine to know missing a shift point (which I've done lots LOL) unless you hit the limiter will maybe affect ET a few hundredths. She's doing good and will get better and more comfortable with seat time. Getting a clutch to be perfect can be tough. Once you get the racepak working it will be an amazing tool to make sure the clutch is working as it should. Have enjoyed following the build of the Nova.
68 Chevy11 327 F/S |
#1613 |
That's basically what I came up with, and the DA was 2800'. I'm pretty sure there's another .10+ in tuning and a gear swap, I'm ok with that for a start.
Todd Greene |
#1614 | |
Todd Greene |
#1615 | |
Liked 544 Times in 213 Posts
I wired the stock horn button to work the line lock on our ‘68 Nova back in 1969. That car had a built in rev limiter. It would just go flat at 6000 or less with what we had to work with back then...Some cams pulled up a little higher at 6200.....Hydraulic lifters, stock springs, stock rockers. 12.20’s at 114+ was best numbers back in 1970 on 7” tires ! 10-1 compression 350... The clutch was low tech. Schiefer RevLoc diaphragm clutch, 10-1/2” GM disc 11” 30lb wheel.
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 09-30-2019 at 09:05 PM. |
#1616 |
Kinda wonder who I'm discussing this with now.
So, okay ,if you think 7000, make that 7500 on the burnout is necessary and good for the valve springs, etc. , is the right thing to do, and I'm wrong, then tell Autumn to keep doing it..By all means ;-)
#1617 | |
Todd Greene |
#1618 |
60' is off, needs some clutch at the hit. If you dump the clutch at 5k the wet tires won't turn a lick, low base all counter. The only reason it stopped at 7500 is because thats where the chip is, were here to run heads up and haul *****, if we have to turn it 8k and buy valve springs, we'll throw a couple sets in the trailer or we'll fix it when it snaps something off. How's that saying go? We're here to chew bubblegum and break valve springs and we're all out of bubblegum!
Todd Greene |
#1619 | |
Forgive me, guys. Carry on..
#1620 |
It's all good!
Todd Greene |
