#1631 | |
Liked 508 Times in 92 Posts
Casey Miles Stock |
#1632 |
1970 LT1 , 360 hp, now 320 with manual trans. ;-)
#1633 |
Really really hot here at VMP, made a clutch adjustment and two test runs today. About .05-.07 slower than our test last week but Good weather is on the way. Too hot so I'm going in the a/c for a bit then doing carb work tonight. Shot an in car video and you can clearly hear the car labor in high gear till maybe 6100 then takes right off till about 6900 at the finish. Making some shift light adjustments for tomorrow.
Todd Greene |
#1634 |
1967-69 Z/28 302, 290 HP from factory, 309 NHRA Factor. That same 350 that you mentioned, only has to weigh only 110 lbs. more than the 302 in E/S. The 302 is factored to 1.023 HP per ci, the 350 since it's basically the same engine just more cubic inches should have the HP factor of 358 HP fallowing the same formula. NHRA gave that engine combo a gift.
Casey Miles Stock |
#1635 |
Liked 544 Times in 213 Posts
The LT-1 is indeed a Big cube Z/28.
My friend had a 70 Yenko Deuce and it was a very fast car. Engine broke a rod and I put a Z race engine in the Deuce. That friend had a ‘69 Z racecar. I made some runs in that one. The Deuce was still very fast with the 302 in it, Street car with very steep rear gears. Those 2 cars were probably my favorite cars I’ve ever driven. The 69 Z would be worth a fortune today. Who knew !! 😂
#1636 | |
That’s awesome ! That dyno you tested the engine on must be awfully stingy on readings or something changed a lot. Those engines generally pick up a lot in good air. Good job !
#1637 |
Liked 165 Times in 59 Posts
if stockers are out first tomorrow 9:00 am ,that et will be quicker ,get your race pack ready to log those O2's
your getting there ,, I need to find more as well ,,I will be watch d1tv |
#1638 |
Yes, I was told the dyno was not a hero machine.
Todd Greene |
#1639 |
I'll assume the air will be better here on out, I don't know about the car but I know I'll feel much better about it.
Todd Greene |
#1640 |
Liked 372 Times in 129 Posts
