Old 10-05-2019, 06:33 PM   #1661
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: H-I-J '76 Nova re-fit.
What's up in the 1st rd,on live timing it shows the car dialed at 11.30 and no other incrementals.Shows Cagnazzi the winner...gsa612 *edit* we both posted at the same time.I had the rotor loosen off tore the s*** out of the cap.
Old 10-05-2019, 06:33 PM   #1662
Nmbr1GMfan
We had a great matchup with Victor Cagnazzi today for first round which was kind of cool since Autumn first met Victor about 2005 and he has always been super cool. Unfortunately, in the burnout the car just abruptly shut off, got it back and started checking everything (we were expecting the worst) and turn out the little screw on the rotor came off and poof... the two piece rotor is in fact... a two piece rotor (maybe we need a Loctite sponsor). So Autumn has surmised that possibly our pass this morning wasn't what we thought it could have been because of a possible timing issue. Later testing will determine that. We'll leave tomorrow morning for home.
Todd Greene
Old 10-05-2019, 07:34 PM   #1663
FED 387
Liked 333 Times in 180 Posts
Todd and Autumn---that might partially explain why the engine did not want to rev under a load as it was "partially retarding the timing" --- might want to replace the cap along with the rotor and in the future put a drop of loctite or silicone on those threads to keep them snug---its possible in all your thrashing and assembly that the "screw" really never was tightened merely snugged from the get go---I'm impressed its all coming together very nicely --- Optimistic for your future results--- might want to RE-DYNO the engine in an as is configuration and then try "some things" on the dyno to see what it likes--- looking for that sweet spot so to speak---Regards FED 387
Old 10-05-2019, 10:53 PM   #1664
Nmbr1GMfan
Totally my fault, I remember tightening it on the dyno but didn't use Loctite, just the little spring washer. Won't make that mistake again. I truly believe now (might be wrong) our old headers would cure the issue of pulling down low, they also might cause a horsepower problem up top though too. Maybe I just need some collector extensions, testing will sort all this out. We'll probably put some new plugs in it and swap headers for Rockingham to see what it does.
Todd Greene
Old 10-06-2019, 10:51 AM   #1665
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: H-I-J '76 Nova re-fit.
I just went out and pulled the distributor caps on both my Monte Carlo and my wagon and put a drop of blue Loctite on the rotor screw threads. A thing like this is worth checking. One thing about race cars, you never seem to run out of things to do where they are concerned.
Old 10-06-2019, 01:20 PM   #1666
Nmbr1GMfan
That's the plan, I hope some of our miscues help a few out. We certainly have made our share.
Todd Greene
Old 10-06-2019, 04:18 PM   #1667
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Just a heads up....
The screw coming loose on the 2 piece rotor will only change the rotor phasing and not the timing..
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
Old 10-06-2019, 10:09 PM   #1668
Nmbr1GMfan
Originally Posted by Bob Mulry View Post
Just a heads up....
Just sayin'
Then the timing was ok, rotor phasing, not so much.
Todd Greene
Old 10-06-2019, 10:42 PM   #1669
Nmbr1GMfan
After some maths and assumptions, if we move to our natural class (I) our -.639 could be a -.689 and with a couple issues we have sorted out I honestly think we could go .80 under in great weather. Probably not with the old headers we're going to try, but if I can get some torque back with a collector swap or extensions on the new headers or maybe a gear swap (have to check the tach first) we might get close.
Todd Greene
Old 10-07-2019, 07:19 AM   #1670
Liked 10,769 Times in 2,238 Posts
Back to back at the track. It's work but it beats wondering.
