Old 02-23-2020, 09:24 AM   #321
jmcarter
jmcarter's Avatar
Liked 3,231 Times in 982 Posts
Default Re: Dumbo The Flying Elephant
Would be great to see you and Patsy at the Baby Gators if you can make it; it was an awesome event last year.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-24-2020, 08:44 AM   #322
Liked 10,916 Times in 2,256 Posts
Maybe the Atlanta pts meet. The engine is at a stopping point, it holds water and we, Cooter has a tune in it. We have yet to get A to B, trans ratios (Joel has helped), converter flash, shift points, starting RPM, and shock settings, just to name a few.
Condensation in the valve covers seems like a lot to me, but zero water in the pan. The engine makes good power a little north 7000 RPM. After racing a 440 all these years that seems like a lot of RPM's. It sure sounds good on the dyno.
My job at the dyno was easy all I had to do was stay out of the way. Sid operated, Cooter did the tuning, and Shawn did most everything else except supervise. Supervision was left to the master, Mr. Jeff.
Two days of fun at the dyno, I just love it!
Old 02-26-2020, 08:59 AM   #323
I will be fine tuning my push-rod instillation tool today. Failure was caused by push-rods being to large, rods are much bigger. I have to figure something out on the exhaust side, its real busy up top. You cant see anything without a scope.
Old 02-27-2020, 08:26 AM   #324
What a day, nothing worked that would repeat with the exception of gravity. The bright spot is; its a solid roller so I will not have to pull the head to install a solid lifter for checking valve lift.
I'll try something different today.
Old 03-05-2020, 09:34 AM   #325
Change filters, add oil, install engine and trans. One step closer.
Old 03-11-2020, 08:39 AM   #326
I finally got the above post done.
I had some good reasons why it took so long. A lingering cold, and a Grandpa. Its fun being at the granddaughters Basketball, soccer, and volleyball games. I know people outside the states of Kentucky and Indiana do not Capitalize the word Basketball. I'm not sure what the penalty is in Indiana, but here in Kentucky it's not a felony but darn close.
Old 03-14-2020, 08:11 AM   #327
I have drive train installed. I have different shaped bolts for engine mounts, and transmission mounts. Both had same size bolts, now head size and flange is different making it easier to assemble. Best thing about this installation is never having having to use the ill fitting CSR shield. I want to say more about CSR but I won't, you get the picture.
Old 03-14-2020, 10:31 AM   #328
340Cuda
Liked 805 Times in 341 Posts
Larry,
I apologize if I missed this earlier in this thread, but what did you use that fit better than the CSR.
I am not a big fan of CSR either.
Thanks,
Bill
Old 03-14-2020, 10:51 AM   #329
TCI shields and a BFH. It ain't easy or fun adjusting stuff to make it fit. I don't think the knot on my left thumb will ever go away, missed swing of a four lbs hammer.
Old 03-14-2020, 11:56 AM   #330
MR DERBY CITY
Liked 8,206 Times in 1,536 Posts
Larry, its a shame that DUMBO is all dressed up , with no place to go.... I followed your build very closely....
