Old 05-07-2020, 08:37 PM   #1
garylanders
Default Voltage reducer Voltage step down
Anyone use a voltage reducer for accessories that are 12v when using a 16v charging system?
garylanders is offline   Reply With Quote
Old 05-08-2020, 07:35 AM   #2
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: Voltage reducer Voltage step down
Never had the need for step down. Fuel pump, water pump, fan, data logger, ignition all are compatible with 16v systems that charge at 19+ volts.
Some have said incandescent bulbs don't like the higher voltage. In my 15 years of racing on 16 volts, I've blown maybe 2 tail light bulbs.
Todd Geisler is offline   Reply With Quote
Old 05-09-2020, 10:10 AM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Most newer fuel and water pumps will tolerate the 18 volts that a 16 v system will see when charging with an alternator .
What I have seen is cooling fans being damaged by the higher voltage.and also incandescent lighting on the car ....Also COPO Camaro's and DragPak smart window modules will not tolerate the higher voltage .
I use this voltage reducer that is made for electric golf carts to drop the voltage down to a usable 12-14 volts for radios and other accessories .
https://www.golfcartgarage.com/golf-...BoCLLMQAvD_BwE
Old 05-09-2020, 03:33 PM   #4
garylanders
Thanks for all the info I appreciate the replys. I have an onboard air compressor and it seems to run fast with the 16v.
