Old 07-30-2020, 05:01 PM   #1
gnicholson
Liked 4 Times in 3 Posts
Default Hood to carb clearance
Got a new 532 installed in my 70chevelle. With the 4inch cowl induction hood I have 2 inches of clearance between the hood and the flange of the carburetor. Gen consensus is that 4inches is minimum before airflow robbing turbulence becomes an issue. An aero scoop is prob the best performance wise but even with a lot of surgery to make it smaller they still don't look right on the car in my opinion. They make a Sunoco style cowl induction hood that's raised in the middle and then tapers back towards the windshield. Does anybody have any idea what I should do with this thing
gnicholson is offline   Reply With Quote
Old 07-31-2020, 08:19 AM   #2
Hacksaw
Liked 311 Times in 175 Posts
Default Re: Hood to carb clearance
I'd try it like it is. 2" should be ok.
Old 07-31-2020, 05:04 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
2" is not enough . .......first thing you will notice is fuel staining on the bottom of the scoop from reversion . ...4" is minimum , more is better to allow the air flow to straighten out and minimize turbulance.
I picked up nearly 2 mph going from 2" to 5 1/2"
Accompanning pics are from a customers car but I did the same thing to a similar scoop for my car .
no one really makes a scoop that is a reasonable length for a Sportsman style car so get out the saw and the resin . ....No big deal to do .
ID:	55188   Click image for larger version
ID:	55189   Click image for larger version
Old 08-01-2020, 11:28 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
x2. I’d try it.
Before I started throttle stop racing, I always ran the stock hood which didn’t have near 2” of clearance. I didn’t notice any difference in performance our consistency with the 4” cowl.
S/ST 51
S/C 53
Old 08-05-2020, 06:27 PM   #5
Jim Caughlin
Liked 805 Times in 245 Posts
In SS where stock hood is reqd, there was a test lowering a sheet of plywood over the carb, the height number where performance dropped off was 2" over the stock choke horn.
Jim Caughlin is offline   Reply With Quote
Old 08-07-2020, 06:16 PM   #6
gnicholson
I've decided to glass an aero scoop into the hood. I would post a pic if I knew how to do it
