Old 05-11-2020, 06:05 AM   #1
Greg Barsamian
Liked 427 Times in 97 Posts
Default "Best" Between Round Battery Chargers
What are the "Best Battery Chargers" to use for between round charging?
We've used Schumacher, Sears/Craftsman, and Optima Digital Battery Chargers.
Curious to see what others are using and reasons/benifits/opinions why?
Thanks
Old 05-11-2020, 04:47 PM   #2
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
Default Re: "Best" Between Round Battery Chargers
Greg - I used harbor freight - it's cheap and does the job! (I turned Greg Gay on to one of these and he bought one too).
Name:	battery charger.jpg
Bob Don 128 SS
Old 05-12-2020, 12:28 AM   #3
voltdr
Liked 100 Times in 51 Posts
This question is so vague. It depends on what type of battery you’re trying to charge. Also, are just trying to make the next round or trying to get the most life from the battery? Charging a battery incorrectly will cause premature failure.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 05-13-2020, 03:58 PM   #4
Hacksaw
Liked 312 Times in 175 Posts
Can't say it's the best but I've had a Morosso 12v/16v charger for almost 20 years. Use it on everything. Still love it, won't jump start but has sleep mode.
Old 09-03-2020, 03:11 AM   #5
GTX JOHN
We use the same Harbor Freight chargers on our conventional batteries. Optima charger on the Optima batteries at Track.
Back at the shop with more time = Optima's on all of them.
BUT the Optimas are expensive/Hard to Find anymore AND
rather Fragile!
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 09-03-2020, 02:42 PM   #6
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I've been using a Schumacher Ship-N-Shore Model XCS-15 I bought at Bass Pro-Shops. It charges Standard, AGM and Gel batteries at 3 or 15 amps, and gives you a "% of charge" as well as voltage.
The only downside is that if your Optima is heavily discharged, the Auto-Voltage feature doesn't know it's a 12-volt battery, and will only charge SIX VOLTS. You need to hook up another good 12 volt battery to get the charger to work properly. That shouldn't be an issue with between rounds top-offs.
Good Luck!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 09-29-2020, 03:59 PM   #7
cad
cad's Avatar
Liked 93 Times in 52 Posts
I forgot about this one. Luke Siebert uses one on his camaro and nova.
https://cloreautomotive.com/product/pl2320/
It has a 20a charge, which is higher than most, and the company is out of Lenexa, KS.
It is $79 on amazon prime right now. -- https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just ordered one as we have been using my dad's stand-up NAPA charger, but it is a big machine, and Im getting tired of moving it around/loading/unloading.
Clark
