Old 11-29-2020, 07:48 PM   #81
Marty Knox
Liked 44 Times in 19 Posts
Default Re: Not for Nuthin' But Close!
Originally Posted by Glenn Briglio View Post
What is the compression ratio of this engine? What fuel being used ? Fuel table would be cool.
The advertised compression ratio is 10.00:1.
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
Old 11-29-2020, 10:03 PM   #82
Doug Hoven
Liked 867 Times in 165 Posts
The combustion chamber design has some hemispherical properties, so more timing didn't seem to do any good. The fuel is 100 octane unleaded Sunoco 260GTX. The only fuel settings I can mess with are power enrichment (only active in closed loop), and injector pulsewidth multiplier vs manifold vacuum. For this reason I decided to run the car in open loop at all times and take control over the amount of fuel going in. With it in closed loop the ecu kept commanding the afr to be richer and richer and I couldn't get it under control. Attached are photos of both the injector pulswidth multiplier and the minimum spark table.
Name:	cavalier fuel table.JPG
ID:	56394   Click image for larger version
Name:	Minimum spark.JPG
Old 11-30-2020, 07:57 AM   #83
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Ok cool.......what can you adjust in open loop? Can you monitor a/f ratio?
Glenn Briglio is online now   Reply With Quote
Old 11-30-2020, 08:36 AM   #84
Doug Hoven
Yes and No. There is an afr shown in the data log, but it shows that it is the commanded ratio by the ecu. However, when I started to mess with fuel, it did start to show leaner values. The 02 voltage is also shown, and is somewhere around .8 - .9 going down the track.
Old 11-30-2020, 09:35 AM   #85
jmcarter
jmcarter's Avatar
Liked 3,212 Times in 980 Posts
Just FYI that Mike Cashman has posted pics of the car in the FB Stock and Super Stock Racing group, assume the pic has Doug and Billy in it. Very cool little ride.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-30-2020, 10:41 AM   #86
Doug Hoven
That's not me next to Billy. That's the guy that was running the staging lanes.
Old 11-30-2020, 10:47 AM   #87
Glenn Briglio
.8-.9 is what in afr?
Old 11-30-2020, 10:56 AM   #88
Doug Hoven
After some research, this is about 12.8-12.9 in terms of afr.
Old 11-30-2020, 11:00 AM   #89
jmcarter
jmcarter's Avatar
Thanks Doug, I’m learning!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-30-2020, 12:01 PM   #90
lvd2340
lvd2340's Avatar
Liked 4 Times in 2 Posts
Send a message via AIM to lvd2340 Send a message via Yahoo to lvd2340
Threads like this are always my favorite.
Billy Kirpens Jr / Pro ET / Street ET 123J @ Lebanon Valley Dragway
Stock/Super Stock 123A
lvd2340 is offline   Reply With Quote
