#111 | |
Liked 735 Times in 386 Posts
I see they have made the P/S more efficient. ![]() Stan |
#112 |
Liked 354 Times in 120 Posts
Gm systems run a lot of pressure. When running a gm pump with a Mustang II rack you need to drop the pressure or you will blow the seals out of it. Borgesen makes a simple kit for this. Not to be confused with the flow reducers with a smaller hole in them. Gm also has a cold climate PS Fluid. I did not think it would slow the cars that much but your testing shows otherwise. Saturns have electric PS and have plate over pump hole, bolts rite on. I am told the VUE cams made more torque but they do not have the drive for PS. I have one if you want to try it. Tom
Tom Meyer 5240 SS Stock ??? Last edited by Tom Meyer; 12-12-2020 at 12:50 PM. |
#113 |
Liked 17 Times in 3 Posts
Just FYI, due to this post, I have been convinced to build myself a dime rocket.. So it wasn’t for “Nuthin”.. Just letting you know!
#114 |
Jake, you're making me cry in my tequila....Thank You!
#115 |
Great... Show us the details and progression, here.
#116 | |
Liked 98 Times in 31 Posts
#117 | |
#118 |
Liked 783 Times in 195 Posts
Oh, no!! Another Billy-ite!! Or is that a Nees-or-ite?!? . . . and right here at Christmas!
#119 |
Dwight, poke fun if you want but I haven't had this much fun since I was a teen and discovered girls!
I also haven't learned so much, so easy, since about the same time. Doug and I went racing yesterday. I'll report back later.
#120 |
We went to Cecil again yesterday. It was pretty foggy until about Noon and then the sun came out and it warmed up to a bit over 60* but it was still a bit on the damp side. I've been given my "walking papers" and am no longer the driver. The kid has taken over in that capacity too.
He made 6 runs. The first couple of runs were addressing some "issues" that we were having with the trans slipping into the gears when all of the torque management nannys were turned off. To begin with, he turned the torque management back on but has it removing only half of the timing that it was and he raised the line pressure a bit. And if I'm explaining any of this wrong, I'm sure that he'll be posting on here eventually. First pass, with the engine pretty warm and just seeing how the shifts respond to the changes was a 15.28/88.16 Second pass, with the engine cooled down BUT with a "coming-and-going" gusty tail wind, 15.226/89.49. Third pass, I removed a 22" long pipe that I put on the exhaust pipe when I cut the cat. converter off and it seemed to like that, 15.177/89.77. Fourth pass, Doug took out a bit more fuel, 15.158/89.57. Fifth pass, took out a bit more fuel, 15.130/89.43. Last pass, we charged the battery and got the car really cooled down. Doug also took out some more fuel and for the last pass of the year, 15.085/ 89.88! Over a half a second under with a totally stock, junk car! Of course it was with the help of HP Tuners and a 17 year old punk but hey. Thanks for all of the support of the racers looking in here on ClassRacer! I'm pretty sure that Doug will be looking in just in case there are any questions asked that I can't answer. So my X-mas wish for this year is to see a few of these cars getting built. Of course you'll have to post the builds on here. I'd ALSO like to see somebody like Chris Hill drag home a JYD Neon and wring it out. Oh and will somebody get NHRA to put a 2000s FFFord Fiesta in the guide? Then there could be a 3-way "Junkyard Shootout"! Thanks all!
