Old 02-03-2021, 09:52 PM   #11
HP HUNTER
Liked 373 Times in 129 Posts
Wink Re: I'm going to build a smooth idle 427 and drag test it
Nice, but where are the oil pan pics ?? ......LOL. .....
Here you go...........Now I think I told you this could be illegal, but you said paint it black and run it
ID:	56735   Click image for larger version
Old 02-03-2021, 10:11 PM   #12
HP HUNTER
Default Re: I'm going to build a smooth idle 427 and drag test it
Originally Posted by Tim H View Post
No concerns going +.100 over with a production 2 bolt main block ?
I did sonic ck the block, and moved the bores accordingly. At this power level I'am not concerned, its well sealed up. This project was also about using parts I had lying around that I wouldn't use for a customer. When your constantly building higher HP engines, for me sometimes its nice to have a smooth idle mild engine on the dyno, and I was told by the experts on other forums the factory 350 HP 396 cam was a disaster that couldn't make power. I did a 350 HP 396 built back to factory specs but blueprinted a while back and it idled at 750 RPM with a very smooth idle and ran so nice, made 405 HP @ 5600 RPM, I really liked it and wanted to see what a 427 version could do.
Old 02-03-2021, 11:17 PM   #13
HP HUNTER
More pictures
ID:	56737   Click image for larger version
ID:	56738   Click image for larger version
ID:	56740   Click image for larger version
ID:	56741   Click image for larger version
Old 02-04-2021, 09:45 AM   #14
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
:Like a factory 385-390hp 427, only bigger. The factory did the same thing, even the 360hp & 390hp 454 in 1970.
Old 02-04-2021, 11:58 AM   #15
I would guess that you would want a converter that's tighter than what's normally in the Chevelle.
I suspect the dyno test will bear that out. Nice job.
Old 02-04-2021, 12:56 PM   #16
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Re: I'm going to build a smooth idle 427 and drag test it
I have a hunch this will be far more potent than it looks....
Wayne Scraba is offline   Reply With Quote
Old 02-04-2021, 06:25 PM   #17
MR DERBY CITY
Liked 8,021 Times in 1,526 Posts
Nice pics, but your memory is suspect....LOL !!!!
Old 02-04-2021, 10:36 PM   #18
Any readers here care to guess on the dyno HP ?
Don't be shy... No offense taken, I'll bet. ;-)
Old 02-04-2021, 10:43 PM   #19
HP HUNTER
The cam is the obvious cork. The blueprinted 350 396 made 405 HP @ 5600 RPM with I think 408 cubic inches, so it would make sense it would be around 1 HP per inch, is what I was looking for. A better question is: how much average power over a certain RPM range does it take to run 11.00 @ 3500 pounds, anyone.............
Old 02-04-2021, 10:49 PM   #20
HP HUNTER
The cam is the obvious cork. The blueprinted 350 396 made 405 HP with I think 408 cubic inches, so it would make sense it would be around 1 HP per inch, is what I was looking for. A better question is: how much average power over a certain RPM range does it to run 11.00 @ 3500 pounds.
