Old 02-20-2021, 11:17 PM   #21
Liked 5,121 Times in 1,952 Posts
Default Re: It's About Time (Not MPH)
Originally Posted by nickh View Post
Mark you putting lightweight paint on the car?
Sure am...from the doors back ;-)
Old 02-21-2021, 07:34 PM   #22
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Talking Re: It's About Time (Not MPH)
Nothing exciting here, but I thought I'd do an update for the three or four people that follow stuff like this.
So you’ve been hard at it, looking a damn sight better than when I first saw it, lol 😂!
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 02-22-2021, 03:30 PM   #23
BigBlockBill
Liked 98 Times in 31 Posts
[QUOTE=Mark Yacavone;630985]Look what followed us home today...
I see Ford uses the same clear coat at GM..Black car,..in San Diego yet.
That's okay...Have d/a, will travel.
Leave the paint alone, its a weight savings.......lol
What happened to the trailer you built for it?
BBB
BigBlockBill is offline   Reply With Quote
Old 02-22-2021, 04:21 PM   #24
[QUOTE=BigBlockBill;635013]
BBB
All that happened with it is I hauled it up to Prescott for inspection.
Inspection, VIN, tax, title , permanent plate, and oh yeah, road use fee. (CA. trick they picked up over here) total $191.00 Probably cheap, compared to some states.
Leave the paint like that? I guess you don't know me very well..LOL
Old 02-24-2021, 12:55 AM   #25
This thing is starting to get expensive...I had to buy a line lock for it the other day..
Old 02-28-2021, 09:16 PM   #26
HP HUNTER
Liked 372 Times in 129 Posts
[QUOTE=Mark Yacavone;635022]
I know you well...............and I know your extremely fastidious
Old 03-11-2021, 11:07 PM   #27
Not a lot of bubblepak- ing going on yet..
Little bit..
New countenance here:
I decided I didn't want to spend 25 bucks and four hours, polishing headlights..Not when I could get a new pair for 48 bucks, free shipping.
Solid mounts all welded up and fitting to the transaxle and block. I gave the t/a a bath and a spray can rebuild. Hoping for the best ;-)
[/url]
I remembered that the crossmember that two of the mounts sit on, was rubber mounted too, so I did a quickie solution on that.
This doesn't look much like a header yet, but I promise it will, when I get the head back and put this thing together.
Old 03-15-2021, 11:51 AM   #28
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
What class you plan on putting this into ?
Jake Biermann
Old 03-15-2021, 12:06 PM   #29
EF/S
Old 03-21-2021, 12:40 AM   #30
I had a couple more pics that I neglected to include in the last update, so here ya go}
The bracket that holds the alternator, also held the p/s pump and A/C compressor.
I attacked it with a Sawzall and left just enough I think.It also bolts to the head. I had to rotate the tensioner to the left and then find the exact right belt. (3 tries) but it oughta work okay.
I had to heat the front hubs with an acetylene torch to get the axle out of them, which , in turn , ruined the wheel bearings..The axle splines were choked with rust but I managed to save them by using small cut off wheel on a Dremel tool to clean them up. It all pressed back together fairly easy . ..A few more parts not covered with grease and rust anymore..
