Old 09-21-2020, 07:20 PM   #41
Lyn Smith
Liked 1,001 Times in 203 Posts
Default Re: 1955 Chevrolet Q/SA Build
I currently have a 5;57 and a turbo 350 trans with a 2.74 first gear. The little motor really likes a lot of gear.
Lyn Smith is online now   Reply With Quote
Old 11-27-2020, 07:30 PM   #42
farmco r/sa
Liked 147 Times in 54 Posts
Thumbs up Re: 1955 Chevrolet Q/SA Build
Originally Posted by Lyn Smith View Post
Have been working on this for most of the year.Actually started the motor build last year.It is a 180/197 HP 265.I originally was building a 4 door ,but it is being held hostage in a local body shop.A friend had this pretty solid 2dr that he purchased from a 95 year old gentlemen.He offered it up to me so I could get some runs on it this year.Have had the car out a couple of times and with a not loose enough convertor,and not enough rear gear have been able to run a 13.49 at 97 mph on the Q/SA index of 13.85.Hope to get it to the Earlville points race after Indy for its first taste of NHRA action.Will be picking up a new convertor at Indy, and hope to have it in before Earlville.Will race this car at a few opens,Nostalgia events,and will continue to race the Buicks at National events.Will post more pictures later.
Very cool. Most know 1955 is the earliest year in the classification guide. Nice work
Randy Hyman. Lakewood co. stk 5394
P/SA
farmco r/sa is offline   Reply With Quote
Old 03-10-2021, 10:41 PM   #43
Lyn Smith
It has been awhile but I'm back working hot n heavy on the 55 Q" ship". Body is in the body shop with a late March delivery date promised. I have the powder coated frame at home in the garage trying to get as much done on it as I can so it will be easy swap over when the painted body gets back from the painter. Even going to try and get the brakes bled so I can test all lines, fittings, and new flares for leaks. I will show you how I'm going to do that with the master cylinder mounted on the new frame, and powered up with a pressure bleeder. Engine block is on the engine stand and with the arrival of a few more pcs I will start putting it together in the next week or so. I found one of those rare 548 casting 283 blocks made with the 265 bore. The block is called a poor mans Bowtie, as it has thick walls, and deck. It even got a mention in Grumpy's first small block engine build book. I would really like to have the car ready to test by the end of April but that is going to be pushing it by any means.
Old 03-11-2021, 01:46 PM   #44
jakane254
Liked 18 Times in 5 Posts
Lyn, What style rear and posi unit are you running? I am building a 56 265 stick car.
jakane254 is offline   Reply With Quote
Old 03-11-2021, 02:13 PM   #45
Hacksaw
Liked 314 Times in 177 Posts
Posi unit ?
Old 03-11-2021, 10:10 PM   #46
Originally Posted by Hacksaw View Post
Posi unit ?
Posi unit ?
Old 03-11-2021, 11:18 PM   #47
Lyn Smith
I have a Impala 12 bolt with spool.
Old 03-12-2021, 01:16 PM   #48
jakane254
Thanks Lyn. I'll go the spool route.
Old 03-12-2021, 04:28 PM   #49
Randall Klein
Liked 316 Times in 67 Posts
FWIW: at one time Speedway Motors in Lincoln, NE had a stockpile of NOS Firestone 7" slicks, I'll bet they would work
Just a thought
Old 03-13-2021, 05:06 PM   #50
Lyn Smith
Yes the old blue dots would look cool on it just sitting in a display somewhere, but I will stick with my Hoosier 9 inchers for going down the track. Will be faster and a lot more stabile.I think Coker tire did at one time a few years ago make some repos of the M+ H 7 inchers also.
