#481 |
Liked 355 Times in 136 Posts
#482 | |
Liked 804 Times in 341 Posts
Very interested in reviews both pro and con. Thanks! Bill |
#483 |
Liked 10,759 Times in 2,236 Posts
Consolidating information from working books to a permanent reference by category. I’m to old to remember and Dumbo is more complicated than I ever imagined. Today is bread crum organize day.
#484 |
Liked 7,978 Times in 1,525 Posts
eezrvproducts.com. ........this tire pressure system monitors the pressure and temp of tires. I have used it for a few years and highly recommend it.....
#485 |
^^^^^^^^^^^^^^^That's the one we use^^^^^^^^^^^^
#486 |
To my surprise the largest, most pages, section of my notes is the suspension section on the four wheel scales.
#487 |
For me the biggest question during dissemble is why? Why is there more ware on this side and not the other. After noticing change comes the questions; does it need fixing and if it does how?
Off topic but we are updating our gages in the Cuda to Classic Instruments 40* to 220* water, oil, and trans temp, plus the oil pressure gages. |
#488 |
I removed a piston and rod. Checked the stretch of the rod bolts and the bolts matched the information on my build sheet. When relaxed the numbers agreed again. No sign of cap fretting or back side of bearing insert micro welding itself to the rod. Rings seemed to take to piston and cylinder wall. Top two rings were separated by about 120*, the oil rails were lined up over each other. Was that the reason the top of piston had a little extra carbon build up?
It will be good to know how round and straight the cylinder walls stayed. Our toy airplane engines ran well when they were round and straight. |
#489 |
Selling the Private Lee has been way more time consuming than thought. I'm still finding parts.
I'm sending off a couple of test valves to be coated, I sure hope it will extend the service life of stuff. |
#490 |
Got to finish the boat, then after the Norwalk races it will be focused on Dumbo. We hav a new trans to test and ratios to try
