Old 05-17-2021, 04:35 PM   #1
1791FJA
Liked 5 Times in 2 Posts
Default Vega manual steering box in 3rd gen Camaro help
I picked up a 1990 Camaro that came with Flaming river Vega manual steering box. I noticed pitman arm was not correct. Does anyone know the proper pitman arm & center link combination that is needed to use Vega box in a 3rd gen Camaro? I called Ed Quay and they were unable to help. They suggested I call Speedway Motors. Speedway sent me a pitman arm that has correct offset but does not fit center link ball joint. I believe part # that may work is a 3978040. Any help would be greatly appreciated.
Thanks,
Frank
1791FJA is offline   Reply With Quote
Old 05-17-2021, 08:03 PM   #2
Eman
Liked 133 Times in 76 Posts
Default Re: Vega manual steering box in 3rd gen Camaro help
Only thing I can tell you is I used an S10 box and it bolted right in with factory pitman arm.
Eman is online now   Reply With Quote
Old 05-17-2021, 08:57 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
I have one at my shop and will get you the number off it.
It came with the Gen 3 Quay car I bought as a project.
Adger Smith (Former SS)
Old 05-17-2021, 09:26 PM   #4
1791FJA
I have used S-10 box as well in the past with power steering pitman arm works perfect. Camaro that I recently purchased came with Flaming River Vega box with incorrect pitman arm. Vega box is 10 pounds lighter and would like to make it work.
Old 05-17-2021, 09:30 PM   #5
1791FJA
Thank you, would be great if I could figure this out. I know people have used this set up. Big issue seems to be ball joint size on center link not working with Vega pitman arm.
Frank
Old 05-18-2021, 08:56 AM   #6
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
I believe Borgeson might have the parts you need also.
L78 Nova is offline   Reply With Quote
Old 05-18-2021, 09:05 AM   #7
Dragsinger
Liked 99 Times in 60 Posts
The pitman arm on my 3rd gen with Vega box has been welded. The center link hole was cut from the original pitman arm and reattached to the Vega arm.
Note, the Vega box does have a high steering effort. I built another 3rd gen with the S-10 box, and the steering effort was more agreeable.
This Camaro came to me with the Vega box and the welded pitman arm. If I were starting anew, I will do the S-10 box.
Larry Woodfin 471W
Old 05-18-2021, 09:42 AM   #8
1791FJA
Thank you for checking
Old 05-18-2021, 07:38 PM   #9
Adger Smith
I didn't make it to the shop today, but will tomorrow..
I will dig it out and get the part# for you.
Old 05-19-2021, 12:44 PM   #10
1791FJA
Thank you
