Old 08-18-2021, 08:15 AM   #1
Liked 10,750 Times in 2,235 Posts
Default Cleaning an aluminum head
What is the best way to remove carbon buildup. The wire brushes I used on the iron heads are too aggressive for the aluminum heads.
Thanks
Old 08-18-2021, 08:36 AM   #2
Ronnie Hamlin
Liked 29 Times in 8 Posts
Default Re: Cleaning an aluminum head
3M makes plastic Roloc discs for cleaning aluminum parts. I think they call them bristle discs and are available in different amount of aggressive according to the color. I tend to use the yellow ones
Ronnie Hamlin is offline   Reply With Quote
Old 08-18-2021, 10:05 AM   #3
SSDiv6
Oven cleaner, Super Clean, Brake cleaner, 100 grit 3M Pro-Pad Hand Sanding Sponge and lots of elbow grease.
Old 08-18-2021, 10:15 AM   #4
Greg West
Liked 52 Times in 22 Posts
We used Snap-On (Bluepoint) p/n AC16C wire brushes in our test labs. These brushes would not damage aluminum heads or blocks. The wire diameter is .006" so they are quite soft.
Greg West is offline   Reply With Quote
Old 08-18-2021, 11:06 AM   #5
FED 387
Liked 333 Times in 180 Posts
Larry--- you might look into using Berrymans Chem Dip-# 0996 carb cleaner--dont soak parts for more than 30-45 minutes at a time and "lightly" brush the carbon with a parts cleaning brush ---then take a shop towel and "dry and rub the carbon" it will come off just takes time depends on how bad it is may have to repeat the procedure multiple times--- Dick
Old 08-18-2021, 12:36 PM   #6
I got some Dremel tool wire brushes the steel wire ones last longer than the brass ones. And have some ss steel tooth brushes to use in the runners with brakeclean.
Thanks for all the good ideas.
Common sense in abundance is genius!
Old 08-18-2021, 01:21 PM   #7
pmrphil
Liked 348 Times in 152 Posts
Carb clean will dissolve the carbon way better than the brake cleaner.
Phil Molski
PMR Performance
S/C 1623
Old 08-18-2021, 02:45 PM   #8
Jack Zimmerman
Liked 11 Times in 6 Posts
On my iron heads, bead blasting them in my blast cabinet with walnut shell media works pretty well in the exhaust ports and the other nooks and crannies, etc. as long as the heads are completely disassembled such that you can wash out all of the media with a garden hose and compressed air when you're done. And I've cleaned other aluminum parts with walnut shells as well and they don't change the surface finish at all so I'm guessing that they would work well and be OK on a cylinder head. But you should probably try it on a non-critical area first and start with a relatively low pressure. And if you are not aware, Harbor Freight has the walnut shell media if you need some.
Jack Zimmerman is offline   Reply With Quote
Old 08-18-2021, 03:29 PM   #9
I will shell out some dollars for some shells and some carb cleaner and give it a try.
We have black walnut trees in the yard and to crack the shells it takes a big hammer and safety glasses.
Old 08-18-2021, 08:35 PM   #10
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: Cleaning an aluminum head
I just spit sweet tea outa my nose! Thanks Larry. Jim
