Old 08-16-2021, 08:00 PM   #501
Liked 10,924 Times in 2,257 Posts
Default Re: Dumbo The Flying Elephant
525 miles later the 440 block is honed. This is the block that needs the new pistons and rings, but don’t have either one. As Jeff said it’s going to be plenty loose. I hope it gets me in at Indy. We should get a feel for performance at the BG Pts race.
Old 08-20-2021, 05:38 PM   #502
pmrphil
Liked 379 Times in 153 Posts
We changed rod bearings last time to a different brand and it has seem to greatly reduce the micro welding of the shell to the bore of the rod.
Purchased a Harbor Freight 1/2 ton engine stand what a disappointment. Instead of the engine with a nose up angle it’s a prominent nose down position. Not a good product. I know, I know, what did I expect!
Hey Larry - curious as to what brand you went from and to - care to elaborate?
Thanks, Phil
Phil Molski
PMR Performance
S/C 1623
Old 08-21-2021, 09:32 AM   #503
Cleveite 77 to King.
Old 09-02-2021, 02:02 PM   #504
A/SA class is over and Steve won again, congratulations to Steve Wann. The good news for me is that our car is a little closer in performance than in years past. Going to Jeff Taylor’s shop to get some stuff worked on was for me a good decision. Thanks Taylor and Jeff
After Indy we will drain the brake in oil out and put some racing oil in.
Then back to Dumbo
Old 09-02-2021, 09:39 PM   #505
doglover44
doglover44's Avatar
Liked 493 Times in 231 Posts
When will Dumbo be back at the track ?
Jake Biermann
Old 09-03-2021, 05:17 AM   #506
Dumbo will be back after everything is checked, documented, and improved. We are still trying to catch the yellow car and it’s BAD fast. I need a lot of help in gaining confidence in my ability to tune the car for different track and weather conditions.
Old 10-11-2021, 06:56 PM   #507
Well tomorrow is when the little elephant is front and center in the shop.
The pink car has its last race in BG this weekend.
All year we have been buying parts for Dumbo, cross your fingers.
Old 10-12-2021, 05:11 PM   #508
Fathead50
Hey Larry were you in Indy at the last NMCA event. I didn't get to cruise the pits that weekend. Also did you get the new gauges in the Cuda? it's Scott by the way lol!
Fathead50 is offline   Reply With Quote
Old 10-14-2021, 07:15 AM   #509
We were at St Louis. Gages are great! John and the rest of the Classic team do great work!
Old 10-14-2021, 08:17 AM   #510
Fathead50
when you get time can you send some pictures of the gauges in the dash .If you are able to get some close up and back to were you see the dash it would be great. Are you done racing for the season??
