#61 |
Liked 345 Times in 149 Posts
Not sure what you mean about the starter.
If you mean header tubes and the starter, the closest tube is at least 2 or 3 inches away. can take the starter on and off and connect/disconnect wires without removing any header tubes. |
#62 |
#63 |
Liked 237 Times in 126 Posts
It looked tighter in the photo I was looking at. The sweep of the pipes gives a lot of clearance.
#64 |
Liked 129 Times in 41 Posts
Beautiful work, thanks for posting!
#65 |
Liked 27 Times in 19 Posts
Nice work Todd, I always followed your Malibu build on Team Chevelle. Sure a shame about that car, but glad you came out of it OK.
#66 |
#67 |
#68 |
Next item on the build was to finish up the stainless brake lines in the front. This was really my first time trying stainless which is a bit more of a challenge than your ordinary mild steel hard line. The routing makes this even more of a challenge, but I think they came out pretty well, just very tedious and time consuming.
#69 |
My engine builders son does CNC machine work out of their shop so I was able to talk him into making me this custom firewall mount sensor block for the EFI system. This allows the sensors to stay on the inside of the car to keep from passing so many wires through the firewall and the sensors then get plumbed on the engine compartment side.
![]() Front suspension limiters came in. ![]() Chassis tag installed. ![]() Window new wrapped up. ![]() Exhaust support rods completed. ![]() And starting to mock up the radiator and fuel system. ![]() |
#70 |
Davis didn't have the radiator I wanted (with -16 bungs) in stock and it would have been 8 to 12 weeks wait, but they did have one in stock with 1 1/4" nipples, so I ordered that and swapped the fittings out.
