Old 11-17-2021, 11:14 AM   #1
rocketolds400
Liked 5 Times in 4 Posts
Default LS Style Throttle Body - EFI Stop/Restrictor Options?
Hello all.
I currently run brackets with my LS-based EFI combo, running 10.60's flat out. I'm looking to start running a local 10.90 index class with the goal of moving on to Super Street.
I have a factory LS3 intake with an aftermarket throttle body (cable operated) in the factory location.
Are there any throttle stops or restrictors out there for the factory style LS throttle body setup?
I'm sure I can kill the .3 with short shifting and weight, but just want to see all the options available!
Thanks!
rocketolds400 is offline   Reply With Quote
Old 11-17-2021, 01:03 PM   #2
Keith 944
Keith 944's Avatar
Default Re: LS Style Throttle Body - EFI Stop/Restrictor Options?
I’m sure you could make an in line t-stop work. A little fabrication. You could always use ballast.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-17-2021, 05:21 PM   #3
340Cuda
Liked 805 Times in 341 Posts
It can be surprisingly hard to slow a car down sometimes.
Weight is probably a sure thing.
If your ECU controls your timing you could use it to pull timing out early in the run.
