#11 |
Liked 13 Times in 9 Posts
I have a OTC also ,works well and would recommend it.
#13 |
Liked 17 Times in 9 Posts
I bought mine off a Cornwell truck quite a few years ago. I use mine after every race on both car as part of my routine maintenance, and it's been perfect. I would buy another one if I needed too.
#14 |
Liked 7 Times in 5 Posts
Turns out my brother has a Matco tester that I will be using. Do I need to warm the motor before running the test? It's been parked in my garage for about 3 weeks without being started. Also, what numbers are acceptable? My motor is 447 C.I. with 14.3 compression.
#15 |
Liked 126 Times in 61 Posts
You can leak a motor cold or hot. Just do the same thing each time. A warm motor should leak alittle better the cold. If doing cold just spin the motor over a few revolution to make sure you have some oil on the walls. Certainly under 10% mine usually leak 3 to 5% when fresh cold
#16 |
Liked 45 Times in 32 Posts
Had an OTC for years with no issues
#17 | |
Liked 1,959 Times in 593 Posts
Mike Pearson 2485 SS |
#18 |
Liked 51 Times in 30 Posts
whats normal leak down on a new motor? does it matter what ring package?
thanks mike Last edited by garyc; 01-31-2022 at 04:49 PM. Reason: previous post |
#19 |
most times leak down was used to find a dead cylinder
#20 |
Liked 335 Times in 182 Posts
definitely less than 10% and if you have gapless end rings less than 5%---if its a tight motor AND NEW never started you are going to see about 3-4 to maybe 5 - 6 %---watch for variations between the cylinder readings especially those cylinders that are next to each other-- not small ones like a few percent but big differences like 10-30%--FED 387
