Old 12-29-2021, 02:08 PM   #1
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Default Powerglide Thread Size
I have a new Ultra-Case trans ordered from JW Performance. They are closed for the holidays so I can't get any info from them. I am wondering what thread size they use where cooler lines are plumbed in. Stock PG has 1/8 NPT which adapts nicely to -4 AN fittings. Most trans coolers I've looked at, and the one I purchased, have -6 fittings, which typically are mated to a 1/4 NPT. Any help is appreciated--thanks!
reknapp52 is offline   Reply With Quote
Old 12-29-2021, 06:11 PM   #2
Craig Porter
Liked 97 Times in 25 Posts
Default Re: Powerglide Thread Size
Most aftermarket P/G cases have 1/4 npt and use-6 coolant lines. If you want to use your -4 fittings you could use a brass step down adapter.Hope this helps
Craig Porter is offline   Reply With Quote
Old 12-30-2021, 01:45 AM   #3
reknapp52
reknapp52's Avatar
Thanks Craig, I was really hoping to avoid using adapters. My new cooler has -6 fittings.
Old 01-02-2022, 11:52 PM   #4
voltdr
Liked 100 Times in 51 Posts
No matter what….-4 fittings are too small for cooler flow.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 01-05-2022, 06:23 PM   #5
reknapp52
reknapp52's Avatar
voltdr, that's good to know--could be part of my temp issues.
Old 03-13-2022, 12:21 AM   #6
nomad
Liked 7 Times in 4 Posts
Speaking of JW Transmissions. Scott Fifield, a 10.90 racer just went to work for them in sales.
nomad is offline   Reply With Quote
