Old 06-13-2022, 08:39 PM   #1
GTS340
Liked 1,344 Times in 410 Posts
Default 4 speed set up in a 2013 Challenger
I'm building a 2013 Dodge Challenger with a 5.7 non drag pak. Been doing it for sometime now. Since I've been waiting for parts and waiting some more. I decided to run a Manual transmission. I'm looking for some help on the clutch set up. Of course pictures would be great. I was wondering if a manual linkage set up is being fabricated or using factory hydraulic. New world for myself to adventure in..
Paul Haszlauer
Old 06-13-2022, 11:03 PM   #2
GTS340
Default Re: 4 speed set up in a 2013 Challenger
Here are a couple pictures of the project.
Name:	1 car in the beginning.jpg
ID:	63276   Click image for larger version
Name:	2 Old rear end and fuel tank.jpg
ID:	63277   Click image for larger version
Name:	3 Sunroof panel.jpg
Name:	4 cage work.jpg
ID:	63279   Click image for larger version
Name:	5 car on the trailer.jpg
Old 06-14-2022, 12:07 AM   #3
GTS340
couple more
Name:	5a Roof removed.jpg
ID:	63281   Click image for larger version
Name:	7 challenger Eyebrow.jpg
ID:	63282   Click image for larger version
Name:	8 front struts.jpg
Name:	9 engine compartment.jpg
ID:	63284   Click image for larger version
Name:	10 front brakes.jpg
ID:	63285   Click image for larger version
Name:	12 anti roll bar mounted.jpg
Old 06-14-2022, 10:22 AM   #4
GTS340
project photos
Name:	11 left side carpet.jpg
ID:	63288   Click image for larger version
Name:	15 degree.jpg
ID:	63289   Click image for larger version
Name:	16 water pump.jpg
ID:	63291   Click image for larger version
Name:	19 New rod.jpg
ID:	63292   Click image for larger version
Name:	22 shaker hood pt.jpg
Old 06-14-2022, 11:19 AM   #5
GTS340
Though this is my crazy dream. First thing first. I couldn't have even gotten this far without the help of my very dear close friend Paul Wong. Paul has made a boat load of phone calls and spent half the cost. Also our good friend Mike Blackstone has been building the engine. Numerous delays that Mike has had to deal with. Don Little did the heads for this project after waiting for ever for parts. Don has always been good to me.
Delays for parts has been frustrating. Two years ago I needed window modules. Was told I would be taken care of. Yeah right!. Pistons took the longest in the beginning. I never went through the process of getting a piston approved. Thanks to Paul and Mike. Now we are waiting for Holley to complete their order. Been waiting for the main part of the Holley ignition for near a 1/2 year. Valve covers too. Waiting for a camshaft. A lot of waiting for sure. I hope someone can help me on the clutch linkage set up.
Paul Haszlauer
Old 06-14-2022, 02:36 PM   #6
GTS340
The more I look Hydraulic is the best anyway. Very old school here. Learning as I go. I guess the next question is there a go to Hydraulic clutch set up that beats the stock set up.
Paul
Name:	17 excepted piston.jpg
ID:	63294   Click image for larger version
Name:	23 rearend parts.jpg
ID:	63295   Click image for larger version
Name:	21 right quarter.jpg
Name:	24 New crank.jpg
ID:	63297   Click image for larger version
Name:	18 front lug nuts.jpg
ID:	63298   Click image for larger version
Name:	27 Mike B R E.jpg
Old 06-14-2022, 10:36 PM   #7
Liked 5,121 Times in 1,952 Posts
Paul, I wouldn't use the hyd. clutch..Too many unknowns .How long since you raced a stick car?
You're going to be using "old school' bell, so why not an earlier fork too?
The pedal should be usable. Just copy the older stuff to get your pivot points and ratios figured out.
Besides header clearance, it seems that you'll be better off with mechanical.
I'm dealing with a factory hydraulic system , only because I have to. I have no starting point for mechanical. :-0
Old 06-15-2022, 10:30 AM   #8
GTS340
Thanks Mark, As far as me personally driving a stick. Not since I was very young. I have built all Paul Wong's 4 speed cars though if that throws me a bone. Paul will also be the primary driver but who knows. Actually Paul has all the stick stuff except a flywheel. Maybe once I get the engine in. The old pivot bar deal will become a better vision for me to fabricate.
Then I spent all day yesterday looking for an original clutch pedal for the car. Holy cow parts are just not available anymore. Anyone have a clutch pedal set for a 2009-2014 Challenger?
Paul
Old 06-15-2022, 11:54 AM   #9
340Cuda
Liked 801 Times in 338 Posts
If you have not already, I would check with Cleveland Power and Performance for salvage clutch petal parts.
https://www.clevelandpap.com/
Old 06-15-2022, 12:08 PM   #10
GTS340
all the little things
Name:	26 right mirror delete.jpg
ID:	63309   Click image for larger version
Name:	27 rearend.jpg
ID:	63310   Click image for larger version
Name:	28 right front suspension.jpg
