Old 01-30-2023, 01:57 PM   #1
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Default Any tips on mounting a brake pressure gauge inside my car?
While my dash is apart I’m thinking about installing a brake pressure gauge. Will I need to bleed the line feeding the gauge? Chances are it will sit higher in the car than the master cylinder. Feel free to post pics of your setup. Thank you. Mitch
Mitch Beri- The Motor City
Old 01-30-2023, 02:31 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Any tips on mounting a brake pressure gauge inside my ca
Try this
https://www.speedwaymotors.com/Speed...Gauge,592.html
Sean Marconette
84 Mustang
5060 SS/N
Old 01-30-2023, 02:39 PM   #3
black88coupe
Originally Posted by Sean Marconette View Post
Thanks. Thats a nice setup
Old 01-30-2023, 03:38 PM   #4
Jeff Stout
Liked 708 Times in 285 Posts
I bleed mine with gauge lower then master cylinder. Then mounted on A pillar rollbar. Very easy to see and get pressure right. But to be honest when running footbrake races I no longer look at gauge.
Old 01-31-2023, 11:00 AM   #5
Liked 11,010 Times in 2,263 Posts
Try to use a glycerin filed gage. I believe that they are more durable.
Old 01-31-2023, 08:38 PM   #6
Frank Castros
Lamb Components gauge?
Old 02-06-2023, 01:00 AM   #7
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Bite the bullet and go electric. No fluid in the cabin.
Dale Shearon
68 Mustang 6394
Old 02-16-2023, 07:28 PM   #8
Ben Holt
Liked 113 Times in 41 Posts
I second the electric. There should is almost always a spare port if you're using a Hurst line loc. Or a Tee anywhere in the front brakes. Electric gauge is no mess!
Ben Holt is offline   Reply With Quote
