Old 02-23-2023, 04:00 PM   #771
Liked 11,006 Times in 2,263 Posts
Default Re: Dumbo The Flying Elephant
The old machinist rule: measure twice cut once; and almost right is still wrong!
Old 03-01-2023, 08:12 AM   #772
Broke a stud off in the intake and had to dig it out. It broke two threads below the surface and damaged those two threads. Straighten the threads with a pocket knife. Got two different ez out kits at Lowe’s that worked very well.
Old 03-01-2023, 08:39 AM   #773
Frank Castros
Larry,
The GEN III HEMI is a bear to work on compared to a RB isn't it.
Old 03-02-2023, 08:06 AM   #774
It’s real tough when I do stupid stuff
Old 03-03-2023, 04:49 AM   #775
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
When will Dumbo first hit the track ?
Jake Biermann
Old 03-03-2023, 12:51 PM   #776
When Patsy can go racing in the motor home. I'm hoping we can get the Holley system installed in the car and on the Dyno before we go.
Old 03-08-2023, 08:03 AM   #777
I’ve been studying the new engine management system from Holley. The first items I’m going to get and test is a backup for every sensor. I would feel very silly to travel 600 to 800 miles to race and have a problem with a $30 sensor.
If two identical air temp sensors vary 3 degrees would I need to change the offset to make the ECU supply the engine with identical A/F and spark of the previous run?
Now that I’ve thought about it a faulty O2 could cause all kind of headaches.
Old 03-08-2023, 02:57 PM   #778
Rob Petrie E395
Liked 216 Times in 77 Posts
Larry
How long did it take for you to get your Holley system. I ordered a while ago. Was supposed to ship Monday. Now it reads shipment pending. But if I click on the system I bought. It now reads April 28th ship date. Trying to decide to dyno this thing with the Commander950 Pro system. And make changes if needed. Or wait for my new HP system and harness to get here.
Old 03-09-2023, 12:40 AM   #779
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
With my Holley system, I ordered a complete extra harness. Once you get everything installed and wired in the car, you do not want to have to pull it all out to dyno the engine. Plus, if you carry it in the trailer, it may help if you have problems at the track.
Old 03-09-2023, 09:15 AM   #780
SSDiv6
Get the Rife Sensors. Made in the USA and very accurate. They will also make custom sensors for your specific application.
https://www.motionraceworks.com/coll...s/rife-sensors
