Old 01-19-2023, 02:13 PM   #11
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Default Re: National Record Postings
Originally Posted by Jim Kaekel View Post
https://www.nhra.com/stats/national_records
Glen: I see yours listed from 2022 on this National Record listing.
Record from October 2022 is not listed.
Old 01-20-2023, 04:07 PM   #12
kansas stocker
Liked 250 Times in 49 Posts
Remember the old days when you ran under the record, backed it up, were tore down and then wrote your accomplishment on the side of the car? Your feat was then validated in every issue of ND. Made you a BMF. Sweet memories of days of old. Pete
kansas stocker is offline   Reply With Quote
Old 01-20-2023, 05:21 PM   #13
BRETV
Liked 783 Times in 200 Posts
They SHOULD at least post them in the National Dragster. Couldn't wait to go to the back and see what the new records were.
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
Old 01-20-2023, 05:59 PM   #14
Frank Castros
It used to be a "Badge of Honor".
Old 01-21-2023, 10:27 AM   #15
NSS Rocks!!!!!!!!!!!!
Why do some classes say minimum?
NSS Rocks!!!!!!!!!!!! is offline   Reply With Quote
Old 01-21-2023, 11:56 AM   #16
Hacksaw
Liked 314 Times in 177 Posts
The record stays for two years and then it gets taken off the books, put to the minimum. You must run at least 5 tenths under the min. to set a record as well as passing tech inspection.
Old 01-21-2023, 02:30 PM   #17
Charles Stewart
Liked 755 Times in 213 Posts
Just a little correction/add-on: Minimum are rather set at 5 tenths under the index instead of minimum number
Charles Stewart is offline   Reply With Quote
Old 10-17-2023, 09:48 PM   #18
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
So Charlie are you saying one would have to go .5 under the minimum.or .5 under the index to set the record?
fred goodwin is offline   Reply With Quote
Old 10-18-2023, 08:57 AM   #19
Jim Kaekel
Liked 536 Times in 110 Posts
That is correct, you must go at least .5 under the class minimum.
Jim Kaekel 3836 STK
Old 10-18-2023, 11:49 AM   #20
The minimum that is posted is already .5 under the index. You would only have to exceed that to set a record.
