Old 02-20-2024, 10:10 AM   #31
Liked 11,012 Times in 2,263 Posts
Default Re: JP1738's Stocker and S/G car
The Dodge 440 4barrel did not like the K&N top it was faster with a Ford base and stock Dodge top.
Old 02-20-2024, 02:13 PM   #32
JP1738
JP1738's Avatar
Liked 1,347 Times in 365 Posts
Got the old (a whopping 9 passes on it) transmission out last night and there is a lot of debris and clutch material in the pan. I plan to take it to Billy Ray Varner, a local guy who has set up several transmissions for my dad in the past, who can hopefully pull it apart further and help me diagnose it. I want to watch him do it so I can learn more about how they are assembled so in the future I can do more by myself. It appears the filter did a great job of keeping all the crap out of the converter, you can see the color and quality of the fluid coming out of it in the image below. Going to let it drain really well today and flush it with new fluid a few times, but it appears to have dodged all of the damage.
There are a few pieces of debris in the fluid that you can see in this image, but that is leftover from when the pan came off and made a mess. The fluid coming from the converter was absolutely spotless.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 02-20-2024, 03:26 PM   #33
Keith 944
Keith 944's Avatar
If you run a cooler don’t forget to flush it, or at least blow air through the lines
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 02-20-2024, 04:29 PM   #34
JP1738
JP1738's Avatar
Yes sir I did, put some brake clean through it and blew it out thoroughly, then poured some fresh fluid in it and pushed that through as well.
Dawson Pauley
Old 02-23-2024, 11:45 AM   #35
JP1738
JP1738's Avatar
Smile Re: JP1738's Stocker and S/G car
Posted in another thread, reposting here for continuity,
Boys and girls, we are back! Just reinstalled a brand new transmission curtesy of Scot Lamar last night with the help from my dad and some mountain dew. After flushing the converter once more in a fashion described by Mark's ghost writer, we threw everything back together and got it running again. I hopped in it and took it off jackstands to drive it around the block. Seems to have all 3 forward gears now! I'll get my broken trans torn apart soon and diagnosed. Would like to avoid a similar mishap in the future. If the weather holds out, I'll try to test on Sunday and make sure all is well!
Dawson Pauley
Old 02-26-2024, 12:46 PM   #36
JP1738
JP1738's Avatar
aaaaaaaaaaaaaaand I'm back under (barely).
Managed three .2+ under runs in the 1/8th mile that backs up the runs I made with my other transmission. A little inconsistent, but that could be the track or the small adjustments I made or crummy shifting. Who knows. Looking forward to the qualifying hits and class at the bby gators this week to really put the car and myself to the test to see if we really have a hot rod!
Dawson Pauley
Old 02-28-2024, 01:15 PM   #37
KendallGillespie
Liked 55 Times in 15 Posts
keep up the good work dawson. ill be rooting you on and hopefully catch ya at a d2 event soon, once i get one of my stockers going. from one young gun to another, keep at it.
KG
the slowest EF/S car in the country
KendallGillespie is offline   Reply With Quote
Old 02-28-2024, 03:51 PM   #38
doglover44
doglover44's Avatar
Liked 498 Times in 235 Posts
Hope the car does better at the Baby Gators and no trans troubles
Jake Biermann
Old 03-02-2024, 11:25 AM   #39
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
What track are you testing at?
Mike Moller
NHRA 203 Q-R-T/SA
Old 03-02-2024, 12:17 PM   #40
jmcarter
jmcarter's Avatar
Liked 3,247 Times in 987 Posts
You guys need to keep up, he’s on the Q Sheet in Gainesville with a .377 under, laddered with Harrington if they ever get the track dry. Going to be a lot of bench racing over the next 8-9 days down there.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
