Old 03-04-2024, 10:34 AM   #41
JP1738
JP1738's Avatar
Liked 1,210 Times in 340 Posts
Default Re: JP1738's Stocker and S/G car
Originally Posted by MikeMoller View Post
What track are you testing at?
I test at Shadyside Dragway
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 03-04-2024, 10:49 AM   #42
JP1738
JP1738's Avatar
Well, crap. Don't have any pics to speak of but the Baby Gators was pretty much a disaster. I did manage to get qualified and run under the index, but that's where my luck ran out. It appears that after the heads and intake were surfaced, it moved the distributor too low onto the oil pump and was bound up. Over time it shifted the timing and kept slowing the car down. It had maybe only 28* or so by the time I ran first round and I had no idea. I could only go 13.13 first round. Drove all day back home Saturday and took it testing Sunday to sort out the issue. Timing was one of the first thing I checked and realized it was extremely low. After reaching out to a few people I realized what was causing the issue, I tightened the distributor back down and added a few extra gaskets and it went right back to printing tickets. In 3 runs at Shadyside on Sunday it moved .007 to 60ft and ran 8.00 and 8.02 on the two runs I ran it to the finish line. Dang this has been frustrating but I'm working on it.
I have pulled the plug on the Gator nats and withdrawn. I just can't afford to take my stuff back down there again this week, and so far, the state hasn't been terribly good to me. I'm going to go to my local bracket track and footfeed the stocker to get some more seat-time and continue improving the car. I'll be back to class racing at SGMP in a few weeks, looking forward to it already.
I learned a ton while down in Gainesville this weekend. I got a lot of help and advice from Tim Stickles who helped me go through my Q-jet and show me what did what and how to adjust/change/tune it better in the future. He even loaned me a different hanger and some secondary rods to try. Super awesome guy in person and extremely generous with knowledge and parts. I hate the adversity he faced as his SS car kicked the rods and his stocker was having consistency issues along with mine.
Dawson Pauley
Old 03-04-2024, 02:44 PM   #43
MR DERBY CITY
Liked 7,939 Times in 1,520 Posts
Sorry to hear man, just remember….a distributor with an adjustable collar can be your friend …..
Old 03-05-2024, 11:25 AM   #44
Signman
Liked 269 Times in 99 Posts
As my Dad always told me: "It Pays to Learn"
Old 03-07-2024, 10:22 AM   #45
Liked 10,720 Times in 2,232 Posts
It’s great to know that you have found the ”Speed Secret”, hard, smart work!
You’ll have it flying in no time. Good luck.
Old 03-07-2024, 02:32 PM   #46
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Sucks you had to miss the Gators but keep working at it !
Jake Biermann
Old 03-10-2024, 08:35 AM   #47
Roy Kinslow
Liked 127 Times in 27 Posts
I noticed your PVC valve plumbing. I believe its preferred to have it pull vacuum at the carb base. The way it appears you have it , it is possible for it to lean the mixture only on one or two cylinders. At the carb base it will be more evenly distributed. Might show up more at idle. It's a vacuum leak. Of course your results may vary. Good luck 🙂
Roy Kinslow is offline   Reply With Quote
Old 03-11-2024, 09:24 AM   #48
JP1738
JP1738's Avatar
My carb is not fitted with a vacuum tube at the base right now. I'll look into it when I pull it off again to see if I can see where one is meant to be and re-plumb it if possible.
Dawson Pauley
Old 03-25-2024, 10:18 AM   #49
JP1738
JP1738's Avatar
I did not really come close to winning this race, BUT I FINALLY GOT SOME ELECTRICITY IN MY LANE! Made it to 10 cars on Sunday for by far my best appearance with a long roof. A huge thank you to all the people who have helped me with this car, turns out it’s pretty good when it doesn’t break! Qualified in the #37 position out of 40 cars with a -.19 under run. Once the weather swung, I dialed about -.30 under, so I'm still comfortably in and race-able. Had an unfortunate break-out when the car picked up a few numbers through the middle third round, but not a bad showing at all and I was making the right decision at the stripe, just didn't do enough quitting.
Dawson Pauley
Old 03-25-2024, 07:03 PM   #50
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
Watched the runs, pretty impressive. Believe you have a winnable ride. Good luck in the rest of season
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
