#11 | |
Liked 247 Times in 49 Posts
i agree with above posts. i feel rpm is too low and shifting on time will clean some things up. would like to know if it is gas or alk ep |
#12 | |
Electric shift Gas, C12 |
#13 | |
Yes, on the crossover tube. |
#14 | |
And shifting on time I'd probably be .5 minimum which is after the dip so it probably would make the car more consistent but I don't think it'd fix that problem. |
#15 |
if it were me i would try going on .20 shift at .70 pull rpm up to 4400. you can move the on and shift times if you like to get what you want in 60'. the shift time will typically be 2 to 1. meaning moving the shift .02 will move 60' .01. i would not get tangled up in my mph as long as it repeats and is predictable. trust me, i am not fast either but my car is relatively predictable so it doesn't matter that much to me. i will lose 3 mph in the 1/8 shifting on time vs. rpm.
make a few runs pulling the rpm up and shifting on time. see what the graph looks like and if it is consistent and exactly how much mph difference there is. if you dont like it you can always change it up. also you can move the shift time around to clean up dips and make it better. also if you stay with rpm i would still pull the rpm up on the stop. try that and see what it looks like. i wouldnt worry about creep as long as it repeats. i had a set up one time that creeped 1000 rpm when the stop came off but it was nasty. i agree with lenny about something on the vents to insure you are not sloshing fuel when it goes on the stop. i have a hose that runs from one vent to the other. there are 1000 ways to make a stop work. that is why you have to spend a lot of time testing and playing with things. ep |
#16 | |
Liked 225 Times in 96 Posts
Tony Leonard S/ST 56 S/C 53 |
#18 |
Liked 1,226 Times in 343 Posts
I go on at .30, cruise at 4250-4300 with a CO2 stop and a really fat 30 year old carburetor. That set-up has been pretty good to me in 1/4 mile SST. 383 sbc at 2830lbs (6.30s W/O at that weight), usually 137 mph depending on weather and track.
I change mine to shift on RPM when I run 1/8th mile SST or any S/G, but I use the same .30 on and cruise speed, just add numbers on the back end. Just changing the shift to RPM usually gets me close to 6.90 given I have to go around 7.25 to the 1/8 to get me 10.90 in the 1/4 when shifting on time. It does dip a bit, but not enough to hear or affect much. I can see it on my Mega 400 RPM playback but the resolution is not very fine. Might be worse than I think it is but I think I'd rather just not know. Ignorance is bliss. Despite being slow, I'm more of a "get me close and figure it out before the finish line" kinda guy. Also never really had a T-stop ratio, I just try to get it close.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
#19 |
Liked 192 Times in 83 Posts
I have the same graphs in my Roadster.. if I raise the cruise RPM, it goes away.. BUT, then I have to run more numbers in the box, and stay on the stop longer.. not a fan of that, and it cuts back a MPH or two at the top end, as you're actually shortening the track so to speak..
Adger Smith hit on an important issue, SHIFT POINT.. my stop comes on at .10, and the shift point is .20.. it makes perfect sense that the shift is causing an additional drop in RPM.. especially while taking power away.. I'm going to move the shift point out at bit to see if that's a fix.. the car I worked on this weekend has the stop come on at .10, but the shift is at .90.. graphs look great.. Having a torsion bar front end, I was assuming that the touch down after the launch may have been disrupting the floats, and causing the dip.. NOW, I'm not believing this to be the case.. raising cruise RPM doesn't change the touch down after launch.. WE'LL SEE!!! Last edited by Charlie Yannetti; 05-03-2024 at 11:13 AM. |
