Old 04-30-2024, 10:25 AM   #1
Damn Yankee
Default 428 NHRA Stocker Rocker Arms
I was told NHRA may now be allowing aftermarket rocker arms (Similar to Harland Sharp Non-Adj) to be used in 428 Stockers, as a replacement ? I’m not finding it in the appendage like the Molnar Rods. Brent Lykins makes a nice non adjustable shaft system I’d like to use if this is indeed correct
Damn Yankee is offline   Reply With Quote
Old 04-30-2024, 10:53 AM   #2
fabe427
Liked 13 Times in 9 Posts
Default Re: 428 NHRA Stocker Rocker Arms
Roller rockers have been legal in stock eliminator for quite some time.
fabe427 is offline   Reply With Quote
Old 04-30-2024, 11:05 AM   #3
Damn Yankee
Thank you…..I’m guessing I need to purchase the NHRA Rulebook pertaining to the 428. The rocker arms come in both 1.73 and 1.76 from the factory.
Old 04-30-2024, 11:54 AM   #4
Chuck Norton
Liked 89 Times in 19 Posts
Detailed specifications are quickly accessible through <http://www.classracerinfo.com/>.
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 04-30-2024, 12:33 PM   #5
Damn Yankee
Thank you Chuck; it’s been a little while since I’ve been on the Forum
Old 04-30-2024, 08:47 PM   #6
Liked 1,873 Times in 422 Posts
Get it in writing from Pat Cvengros, or Dave Ley, but the basic intent of the roller rocker arm rule is that the rocker arm must bolt to the head without modification or machine work. I don't see where the rule specifies the method of adjustment, or that the aftermarket roller rockers must be non adjustable if the factory rockers were non adjustable. So you may not need to buy non adjustable rocker arms. I'd see what is available that I wanted, and then contact Pat and/or Dave.
Old 04-30-2024, 09:25 PM   #7
Damn Yankee
Thank you Alan !!!
Old 04-30-2024, 09:51 PM   #8
No problem.
Old 05-01-2024, 08:26 AM   #9
Liked 10,780 Times in 2,241 Posts
Don’t forget to get some really good rocker shafts. Sometimes the ends break off.
Old 05-01-2024, 11:46 AM   #10
Mike Gray
Mike Gray's Avatar
Liked 693 Times in 201 Posts
I currently have the T&D FE rockers and shafts and they work really well so far. My previous engine had POP (precision oil pump) rockers and I liked them also. If you use T&D, you need to use the street rockers because the race rockers are a paired set up with modified mounting and oil through the pushrods which is not stock on an FE.
Mike 7570 A/SA
Mike Gray is online now   Reply With Quote
