Old 05-29-2024, 08:48 AM   #81
goinbroke2
Liked 380 Times in 147 Posts
Default Re: U/SA 302 ffffford build
I only have .382/.398 for lift and 30* is better for flow at low lifts. If i had a lot of lift then id use a higher angle like 60*. The 45* is the factory number and works like factory ?middle of the road?, same as factory cams etc.
Of course i know squat compared to any of the builders on here so maybe they will chime in??
Jim Miller
103 U/SA
Old 05-29-2024, 12:43 PM   #82
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
Are you using a dwell style camshaft ? If so you might want to flow test your different valve and seat angles.
Glenn Briglio is online now   Reply With Quote
Old 05-29-2024, 02:27 PM   #83
Liked 5,109 Times in 1,947 Posts
gb, Suggestion here>
You've got the right cam and carb there. This is an easy combo.
Don't try to re-invent the wheel.
I don't see a flow bench in the the pics, so, in absence of one , you might want to use a 30, 45 sealing angle, 60, 70 and so on,...whatever fits ;-)
Old 05-29-2024, 03:03 PM   #84
goinbroke2
Thanks mark, i was going according to someone else who ran the combo,(very successfully , lol) after grinding a couple practice seats on a garbage head im concerned about the valve drop. 30* was what someone else ran but that was after replacing all the seats. Dont think im there yet, 16 seats for a bit more power?
Im going back out and make a decision.
Jim Miller
103 U/SA
Old 05-29-2024, 04:54 PM   #85
goinbroke2
I have two seats at 30* and im not a fan. So, either get the 45 back or ill have to replace the seats.
I did two others at my regular 15/30/45 seat/60 throat. I thought I had a 75 but i cant find it. Regardless, i like it better and if i lose a bit of power, im ok with that.
I can see why "stock" heads can cost so much! Course if i was better it would be quicker but ive aready got about 17hrs into them with cleaning, guides, porting, (just kidding) lol! Still have to do the valve job and adjust stem height and installed height.. lots of hours left.
I also got one side of the heat crossover in the intake plugged and need to do the other side, little by little, lol.
And thanks to those who pm'd me!!
Jim Miller
103 U/SA
Old 05-29-2024, 10:41 PM   #86
goinbroke2
Earlier tonight, only 11:30 pm, lol.
I didn't like how low the 30* seat was so I tried to save it and did! So I got all intakes and exh valves ground and the valve job done.
15/30/45seat/60throat
After that was done I used lite springs to check stem height. Got them all within .012 by trimming the tip. Now I have to work on the installed height.
Of course nothing is easy, the LED light on my valve grinder went bad and it's continually flashing, try to see where the contact is with that! LOL!
After the heads were cleaned I see this mess in one chamber, not sure if someone chattered a stone or something let go, who knows but how do I fix it or can I fix it since you can't do anything in the chamber?
Still moving forward, so that's good.
ID:	70043   Click image for larger version
Jim Miller
103 U/SA
Old 05-30-2024, 12:02 PM   #87
If I might interject here, for those doing their own valve jobs..Stock valve angle is required in Stock , + or - ! degree.
Old 05-30-2024, 12:07 PM   #88
Glenn Briglio
What angle are you referring to ?
Old 05-30-2024, 12:18 PM   #89
Billy Nees
Liked 7,682 Times in 1,730 Posts
Yeah Mark, it ain't that way anymore. Any valve angle, any number of angles but no further down than the valve pocket and must hold NHRA's runner volumes.
OH YEAH, it has to LOOK "Stock". ;-)
Well ya know? I just re-read the rule book any YOU are correct!
You are however allowed to CNC port the intake/exhaust runners and the combustion chambers! If you're running a FS car. Now that hardly seems "fair"!
Billy Nees 1188 STK, SS
Old 05-30-2024, 05:07 PM   #90
goinbroke2
4th sentence says “must retain stock diameter and angle + - 1*”. But the 4th sentence from the bottom says “any valve job accepted”?
Well i did 4 angles (cant find my 75* ) 15 in the chamber, 30 below that, 45 seat and 60* in the throat. Im pulling my hair out because the flash and casting crap as well as the lip left from the 15 cut is killing flow but i cant legally remove it. Stock casting SUCK!! Lol!
So much easier to make power when you blend, lol.
Jim Miller
103 U/SA
