Old 07-26-2024, 07:37 AM   #131
Liked 10,678 Times in 2,221 Posts
Default Re: U/SA 302 ffffford build
Hang in there
Old 07-26-2024, 04:21 PM   #132
goinbroke2
Liked 380 Times in 147 Posts
Thanks Larry, I'm trying, but now I've got family coming from out of province and when they leave I'll have 3 days to do everything before the Open. I'm thinking it might not happen. The following weekend is another open 7hr's each way so I might try for that. Or...just go to my local track for a test and tune to sort the bugs all out before hitting any S/SS races.
Company coming wants to off road so I have 3 mud trucks to get ready before Monday now...and all my camera stuff and drone for my youtube channel as well....and of course we're on a lake so everyone will want to go in the boats.....busier now than before I retired, lol.
Jim Miller
103 U/SA
Old 07-26-2024, 10:36 PM   #133
Dave Gantz
Liked 251 Times in 125 Posts
That's your ticket, Jim. Get some good, solid runs in before you go S/SS racing. No rush. Remember the old Pennsylvania Dutch saying, "The hurrieder I go, the behinder I get."
Old 07-27-2024, 09:34 AM   #134
goinbroke2
Story of my life! Lol!!
Jim Miller
103 U/SA
Old 08-20-2024, 02:22 PM   #135
goinbroke2
Can't get a break, lol...
Got the converter/transmission and valve body installed.
Got the 5.14's installed
Got header collectors fabbed up and installed
Fired it up and running like crap then quit. No gas in the tank? Whatever, filled it up and squirter is spraying weird. Pull carb and open it up and it is full of brown sludge from the gas tank...crap. Stripped carb and cleaned it, fired it back up, runs good again. (ordering a fuel cell over the winter)
Go through the gears, I have park/reverse/neutral/LOCKED UP/2nd/3rd.
Unhooked the shifter, maybe it's not "perfect"? Nope, same, it's the valve body or what I did or didn't do to it. It feels like a tranny brake, I gave it a bit of throttle and it was torquing against the converter. I ground out the 4 slots indicated and didn't grind the 2 for the tranny brake but maybe I screwed up?
So, once it cools, drain the tranny and pull the valve body to see what I did wrong. I also send a message to Broader performance to see if they can help diagnose it.
Unrelated but also a factor in getting this done, I was diagnosed with an "aggressive" cataract in my left eye and even had to go to emerg one day. Yesterday I found out my cousin (we are identical, everyone calls us twin cousins) has stage 4 cancer.
I always said I don't mind getting old, I just refuse to grow up. Well now, getting old is getting on my nerves too...
Jim Miller
103 U/SA
Old 09-05-2024, 10:36 AM   #136
goinbroke2
Well...first gear is exactly like I have a tranny brake on. Pulled the valve body and stuck in the one out of the white mustang and it works fine (forward pattern with shift kit)
Pulled it back out, went over the valve bodies piece by piece (three of them, one stock, one with a shift kit and one with reverse valve body) all the springs and valve are correct. I've watched video's that broader said to watch and everything is exactly like the video.
Not going in the garage today.
Might modify the stock valve body according to the instructions and see if the second one turns out better than the first.....another day.
Fuel system is totally gummed up now. Bolts for the gas tank are rusted solid (why I never took it out originally) but I'll have to break/cut them off and drill/tap/fix whatever. I have another stock tank with a sump welded in, might use that or a cell, probably go with cell. My nice stocker carb is gummed with crap from the tank so everything has to come apart and be cleaned/replaced.
Could of bracket raced the blue mustang all summer if I wasn't addicted to stockers, lol!
Jim Miller
103 U/SA
Old 09-05-2024, 10:48 AM   #137
Billy Nees
Liked 7,682 Times in 1,730 Posts
Just so you know, unless things have changed since the last time I looked, you can use a cell in a "Stocker" but you can't modify the original tank!
Billy Nees 1188 STK, SS
Old 09-05-2024, 03:28 PM   #138
Cglrcng
Cglrcng's Avatar
Liked 328 Times in 182 Posts
At least they give us all the option today (it wasn't always available). But, if you choose to install a cell, it is also required to remove the stock fuel tank.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 09-09-2024, 07:35 PM   #139
goinbroke2
Thanks guys, simplest things trip you up. Attention to detail and read the rules again, lol.
Fuel cell it is.
Jim Miller
103 U/SA
Old 09-09-2024, 08:22 PM   #140
B/S 428
Liked 154 Times in 34 Posts
Here's a picture of my 79
B/S 428 is offline   Reply With Quote
