Old 01-18-2025, 01:01 PM   #1
my69396
Liked 46 Times in 20 Posts
Default Valve spring tension vs RPM
Does valve spring rate affect RPM and why?
my69396 is online now   Reply With Quote
Old 01-20-2025, 07:55 AM   #2
Rick J
Liked 73 Times in 37 Posts
Default Re: Valve spring tension vs RPM
Yes, rate is control and never changes, though spring pressures will
Rick J is offline   Reply With Quote
Old 01-20-2025, 03:57 PM   #3
Mark Ugrich
Liked 71 Times in 38 Posts
I went through some of this when we selected the valve springs for my S/S heads.Spring rate and the mass in the spring determine the frequency that the spring will operate at.Its possible to have the correct spring rate but not frequency.That said I leaned heavily on the guys at PAC for the right answer.
