Liked 205 Times in 93 Posts
95 camaro, 3200lbs roughly, 350ci/3sd/auto, 5.13 gear. 10.5x30 tire...what rpm will that be in the 1/8th mile? tks for any suggestions,,,
Liked 759 Times in 379 Posts
not enough info for accurate answer but based on what you provided, 6400 rpm max
thankyou
Liked 132 Times in 44 Posts
Go to TCIAUTO.Com On their web sight they have a section for Tech Center, Click on that and then go to technical resources. Then click on Racing calculators. You can figure any of the following 4 with 3 of the variables known.
Rear gear ratio Tire diameter Engine rpm Miles Per Hour. They have many useful calculators at the same place.
Div 3 Sales, Service and Tech for many manufacturers Last edited by Steve Grady; 02-24-2025 at 11:29 PM. |
Liked 2 Times in 1 Post
This formula requires knowing trap speed - which like, if you know that you probably already know what the rpm was:
RPM= (MPH?Gear*Ratio?336) / Tire*Diameter |
Liked 734 Times in 385 Posts
WAG
60 Foot ET = 1.5245 330 Foot ET = 4.5285 1/8 Mile ET = 7.1393 1/8 Mile MPH = 93.8206 1000 Foot ET = 9.4059 1/4 Mile ET = 11.3265 1/4 Mile MPH = 117.8254 5660 RPM @ 660 - with some Converter Slippage Stan |
#7 | |
You will need to adjust for converter slippage. Equation (mph * 5.13 * 336) / 30 Value of mph Evaluated Equation _70.00000 4021.9 _72.50000 4165.6 _75.00000 4309.2 _77.50000 4452.8 _80.00000 4596.5 _82.50000 4740.1 _85.00000 4883.8 _87.50000 5027.4 _90.00000 5171 _92.50000 5314.7 _95.00000 5458.3 _97.50000 5602 100.00000 5745.6 102.50000 5889.2 105.00000 6032.9 107.50000 6176.5 110.00000 6320.2 112.50000 6463.8 115.00000 6607.4 117.50000 6751.1 120.00000 6894.7 122.50000 7038.4 125.00000 7182 127.50000 7325.6 130.00000 7469.3 Stan |
