Old 03-06-2025, 08:55 PM   #1
Liked 10,838 Times in 2,253 Posts
Default How did a milidon 30401 pan become a stock replacement?
Bigger, Deeper, and oil further from the crank. Can the person approving this stuff read a ruler, scales or digital calipers. Reading the vernier on a micrometer maybe out of the question. When was the last time the NHRA tools got checked against a National Standard? How many SBC oil pans are painted black?
Old 03-06-2025, 09:11 PM   #2
MR DERBY CITY
Liked 8,117 Times in 1,532 Posts
Default Re: How did a milidon 30401 pan become a stock replacement?
Larry, not a good idea to POKE the Bear. When you find out the answer to your question, please find out how the 66 Chevy novas got a deep sump pan also ….
Old 03-06-2025, 09:41 PM   #3
Reading a ruler?
Old 03-06-2025, 11:15 PM   #4
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
Cost me an engine, because we didn't check it out. Turns out to be a much larger pan than 5 quarts. And it's in the approved parts list
Kenny Miracle
P/SA 310
kwm is online now   Reply With Quote
Old 03-07-2025, 10:58 AM   #5
Lyn Smith
Liked 997 Times in 201 Posts
Talking Re: How did a milidon 30401 pan become a stock replacement?
That thing is so deep you will have to put 12 quarts or more in it to slow your ol 350 down. LOL
Lyn Smith is online now   Reply With Quote
Old 03-07-2025, 11:14 AM   #6
Tom Meyer
Liked 354 Times in 120 Posts
LSX/LS NHRA Drag Race Pan Kit, 7.5″ Deep, 6 qt, Wet Sump Aluminum Oil Pan 1025-NHRA
$1,085.18Each
Stef?s 1025-NHRA aluminum drag race wet sump oil pan kit. Designed to fit Chevy LS installed in a 2010-2015 or 2012-2015 COPO Camaro. These pans 3/8″ thick side rails for leak free performance. Oil pump pickup, filter adapter and windage tray included.
NHRA approved for Stock Eliminator
For all Chevy LS/LSX Blocks
Clears up to 4.250″ Stroke w/steel rods
Drag baffle with trap doors
Accel and decel ledges
Aluminum bolt in sump tray
Billet aluminum filter adapter
Steel windage tray
Fabricated aluminum oil pump pickup tube
Magnetic drain plug
Mounting hardware included
7.5″ deep pan holds 6 quarts in pan + filter
Tom Meyer 5240 SS Stock ???
Old 03-07-2025, 12:01 PM   #7
The COPO, Drag Pack, and the factory Cobra Jet are all built from catalogs at custom shops. I do not have a problem with that
It is the stuff that is a direct replacement that is way wrong. The comparison is very similar to Larry Hodge and myself. We are both old racers but that is where the similarities end, but we have the same initials. He is regular size and I am slightly bigger by at least three quarts. One Larry is not a direct replacement for the other one.
During having a piston approved I had to supply an OEM piston and my preposed accepted replacement all on my dime. Weight, ring lands placements, compression height, valve notch cc, wrist pin size, and appearance of the top of the piston. To do all of that it took NHRA some time and skill.
My next question is what happened?
Did the acceptance process turn into an income steam for NHRA or did they just lost sight of fairness to the racers.
Old 03-07-2025, 01:09 PM   #8
Liked 5,134 Times in 1,958 Posts
https://www.cfrperformance.com/colle...42121643622648
Same guy.
Old 03-07-2025, 02:28 PM   #9
I know they are out there but how did they get there. If they ant not the same there wrong.
Almost rite is still wrong!
Old 03-07-2025, 02:43 PM   #10
Tom Meyer
HRA Accepted Products
Car Brand Engine Manufacture Part Number Notes
AMC 343/390 Milodon 30780
Chevy V6 CFR CFR-7459-Z
CFR CFR-7465-Z
CFR CFR-7466-Z
Chevy Small Block/LS CFR CFR-7005-Z
CFR CFR-7108-Z
CFR CFR-7208-Z
CFR CFR-9005-Z
CFR CFR-9092-Z
CFR CFR-9414-Z
CFR CFR-9733-Z
CHAMP PANS CP40
Milodon 30401
Milodon 30700
Milodon 30701
Milodon 30702
Milodon 30915
Milodon 31060 Chevy II
Milodon 31501
Milodon 31502
Milodon 31503
Moroso 20180
Moroso 20181
Moroso 20182
Moroso 20211 Chevy II
Moroso 20230 75-79 Monza
Moroso 21151 COPO 427
Moroso 21804
Moroso 21807
Moroso 21808
Stef's 1025 COPO 427
Moroso 21149 LS Engine
Moroso 20138 LS Engine
Kevko Oil Pans 1050
Kevko Oil Pans 1050RH
Kevko Oil Pans 1050NRH
Kevko Oil Pans 2001
Kevko Oil Pans 2001RH
Kevko Oil Pans 2001NRH
Kevko Oil Pans 1069
Kevko Oil Pans 1069RH
Kevko Oil Pans 1069NRH
Kevko Oil Pans 1079
Kevko Oil Pans 1079RH
Highlighted items designate recently added since last revision
Updated Sep. 4, 2024
Stock Replacement Oil Pans
NHRA Accepted
Page 29 3/3/2025
NHRA Accepted Products
NHRA Accepted
Kevko Oil Pans 1079NRH
Kevko Oil Pans LS1007
Chevy Big Block CFR CFR-9294-Z
Milodon 30710
Moroso 20451
Kevko Oil Pans 1
