Old 04-30-2025, 10:14 PM   #1
HP HUNTER
Liked 372 Times in 129 Posts
Default 454 Oval Port Dyno/Drag Test
I put together a 4.310 x 4.00 BBC 467 Cu In, 10.3 compression, 781 oval port heads, 1.88/2.190 valves, Performer RPM air gap intake, 4150 carb with a 1 inch open spacer. Hyd roller cam 238/248/.578/.608/110, 1.7 rocker ratio. My goal is a 9 sec pass in my Chevelle. Here's some pictures of the build.
Name:	Mr particuilair block.jpeg
ID:	72499   Click image for larger version
Name:	mr particuliar assm 2.jpeg
ID:	72500   Click image for larger version
Name:	mr particuliar assm3.jpeg
Name:	Mr particuliar block.jpeg
ID:	72502   Click image for larger version
Name:	Mr particuliar crank.jpeg
Old 04-30-2025, 10:17 PM   #2
HP HUNTER
Default Re: 454 Oval Port Dyno/Drag Test
This combination produced this power @ 900 feet elevation, 29.27 barometer, 84 degrees, 30% humidity, 2500 DA.
Name:	IMG_5196 observed dyno 467 hyd.jpeg
Old 04-30-2025, 10:57 PM   #3
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
9 sec. Run may depend on the weight of the car.
Mike 7570 A/SA
Old 04-30-2025, 11:02 PM   #4
HP HUNTER
My car weighs 3500 pounds race ready, but I do have a weight box, probably be in 2800 DA conditions for the test which is coming this weekend, this is a expedited dyno/drag test.
Old 05-01-2025, 06:55 AM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Did you run the engine to a higher rpm to see when it falls off ?
Glenn Briglio is online now   Reply With Quote
Old 05-01-2025, 09:09 AM   #6
Gary Evans
Liked 16 Times in 11 Posts
Under those conditions, 10.35-10.40
Gary Evans is offline   Reply With Quote
Old 05-01-2025, 09:29 AM   #7
HP HUNTER
Excellent question, no I didn't but we both know it going to have to go 7000 RPM at the line, and I've run that valve train that high before in a 496 before. BTW I'am a BIG fan of the work you do with your Camaro! I'am thinking you've noticed my dyno data other have not. Here's a simulation of a 496 with the same cam and valve train.
Old 05-01-2025, 09:43 AM   #8
HP HUNTER
Thanks for the input, Tx conditions are horrible due to the GOW, its not very often we get excellent conditions, maybe one race a year. This is what I think I will have to work with this weekend. When I lived in Colorado it was always about the baro, when I moved to Tx its always about the humidity, the killer of HP.
80 degrees
78 Humidity
120 GOW
29.5 Baro
2400-2800 DA
475 Elevation
Old 05-01-2025, 09:57 AM   #9
HP HUNTER
Looks innocent.......
Name:	mr particuliar dyno test engine.jpeg
Old 05-02-2025, 04:25 PM   #10
goinbroke2
Liked 395 Times in 154 Posts
That's what I was thinking, climbing slowly so only another hp or two at 6500, so, 606hp, maybe holding to 6700 but I don't see any jumps in power above 6500rpm.
Jim Miller
103 U/SA
