View Poll Results: Yay or Nay | |||
This is a net good |
85 | 44.74% |
This is a net bad |
51 | 26.84% |
Don't care, I'm going to stay in my lane |
54 | 28.42% |
Voters: 190. You may not vote on this poll |
Thread Tools | Display Modes |
#41 | |||
Liked 2,354 Times in 554 Posts
Daren Poole-Adams NHRA Stock/SS 2007 Last edited by GUMP; 06-23-2025 at 02:06 PM. |
#42 | |
Liked 1,874 Times in 422 Posts
Why should a new car immediately be able to negate all of the hard work, development, and investment of combinations people have had for a long time?
Alan Roehrich 212A G/S |
#43 |
People were asking pretty much the same questions when the "supercars" ruined everything in the sixties....
Daren Poole-Adams NHRA Stock/SS 2007 |
#44 | |
"It's happened before" is no excuse for it to happen again. History is to be learned from, not repeated ad infinitum and ad nauseum.
#45 |
I wasn't talking about the cars. I was talking about the crying...
#46 |
Liked 693 Times in 205 Posts
Last year at Indy, there were 5 ?Newer FS cars? in the top 16 for Stock. It seems to have leveled out from 10 - 12 years ago.
#47 |
Do you honestly think that "10-12 years" is a reasonable amount of time for soft make believe paper combinations to "level out? Certainly you must also remember how many years it took some of the modern EFI cars, like the 4th gen Camaros (and Firebirds), with both the LT1 and LS engines to finally move up 5 or 6 classes, and how many older combinations were essentially "Robbed" in Class or heads up races in eliminations.
#48 |
Liked 47 Times in 21 Posts
#49 | |
Liked 401 Times in 158 Posts
Technology is great, but shouldn't replace hard work. So the question becomes, how do you stop newer technology from dumping all over older tech that was messaged to get where it is? Factor it correctly. What happened when fwd cars came out? The hp/weight didn't take into account of the natural problem of pulling the car compared to pushing the car so they were factored by themselves (fwd classes) What happened when turbos became common? Spec's for turbos to prevent "cranking it up and dominating" (buddy ingersol turbo pro stock) What happened when blowers became common? Pulley dia spec's. The common denominator is that newer tech is "better" than old tech so adjustments have to be made. Put it in a class that it doesn't immediately dominate or bump it up a class (add hp) Not against toyota joining the fun, just want it done fairly. It's all a moot point until the first pass is made, then if it's 1/2 sec off the index and has to start like everyone else, fine. If it's -1.00 out of the gate then yes, adjustments need to be made. You can't factor a 1965 sbc the same as a 5.3ls.
Jim Miller 103 U/SA |
#50 |
So, in your world. I can build a 1969 Camaro with a 396/375 that will run 1.20 under and not use one original part in the entire car, that would be OK? But, if I build a new Supra from the ground up using the same rulebook and it runs 1.00, it should be penalized?
