Old 07-03-2025, 03:07 PM   #11
Jim Hawkins
Liked 115 Times in 35 Posts
Default Re: NHRA U Stock dump that clutch
Originally Posted by Paul Wong View Post
This a great altitude combination with a stick
That is good to know, especially coming from yourself.
Thanks!
Jim Hawkins is offline   Reply With Quote
Old 07-03-2025, 04:03 PM   #12
ProfessorRock
ProfessorRock's Avatar
Liked 48 Times in 24 Posts
Beg to differ there MR. Wong . No 2bbl is a good alt. car in my opinion.
And that 2bbl is tiny.How do iknow?lol
Rocketmancoatings
ProfessorRock is offline   Reply With Quote
Old 07-03-2025, 04:06 PM   #13
ProfessorRock
But that is Definately the nicest looking U/S ever.
Rocketmancoatings
Old 07-03-2025, 05:10 PM   #14
Liked 5,147 Times in 1,964 Posts
Originally Posted by Jim Hawkins View Post
How about this combo in a 66 nova. R/S 283/195/164 3122# 13.95 index
Have a nice 66 nova x stocker.
12 bolt slapper bars calvert shocks drum brakes no roll bar
Have 283 parts 2 barrel manifolds couple nova blocks complete 2 barrel nova core motor clutch trans. etc.
Living in Denver if we ever have a track here again probrably not good altitude deal!
I dont know why these slower class combos interest me.
Check with Bill Sempsrott.I'm pretty sure he set a record with that combo.
Old 07-03-2025, 05:29 PM   #15
Paul Wong
Liked 419 Times in 85 Posts
I can go further under on the mountain with a stick 2 bbl than I can at sea level. The flywheel and RPM are the equalizer. At 164 hp its not 302 ford good but a good combination.
Paul Wong is offline   Reply With Quote
Old 07-03-2025, 07:45 PM   #16
Tom Meyer
Liked 354 Times in 120 Posts
Originally Posted by Greg Reimer 7376 View Post
Alright, having been through several 409 powered cars, the logical questions come to mind: 1. What did you do about the rear suspension with the single upper trailing arm that liked to tear loose from the frame at the front?
2. What rear axle assembly is in the car? A 12 bolt comes to mind here. 3. What gear ratio?
4.How about the drive shaft?
5. What is the total weight of this car with driver?
6.How much fun is it to drive? Looks like a real hoot.
7. What is the quickest and fastest time to date?
Best wishes on this project. Looks like a lot of fun.
Converted to a 12 bolt with help from Bich
I was told that some of cars with the high HP combo had two control arms? Watch the tire slow mo and you will see when he shifts to second.
Tom Meyer 5240 SS Stock ???
Old 07-03-2025, 09:14 PM   #17
ProfessorRock
[QUOTE=Greg Reimer 7376;713937]Alright, having been through several 409 powered cars, the logical questions come to mind: 1. What did you do about the rear suspension with the single upper trailing arm that liked to tear loose from the frame at the front?
So Greg ,i am replying only because i have intimate knowledge of those 409s.In 1964 I owned a black 64SS 409-425-4spd.-4:11 posi. I was 19yrs. old. So to address ea. issue from Greg which it sounds like he knows. But the rest of you might find interesting.1. All 64s had the 3 link.and a 10bolt.Including mine. Its what Jenkins used as a model to build some of his first prostocks. Designed to offset the engines rotational torque. 2 orig.10bolt. 65 was first 4link and 12bolt. And i saw no one ripping the trailing arm ,because ? we only had 7inch slicks.OMG leaving at about 4500 and slipping the clutch ,tires spinning -grab 2nd it 's still crabbing sideways untill you hit 3rd. A handfull on the street. Most awesome car i ever owned. See the actual car in my photo album.Raced it 1 time.13flat and one 12.95 i think. won my class but that was it. I was just learning and some kid was not going to beat the older guys. My payment was 62 a Mo.
Rocketmancoatings
Old 07-04-2025, 07:56 AM   #18
joe huestis
Liked 409 Times in 113 Posts
Thumbs up Re: NHRA U Stock dump that clutch
Jim, they interest you and I because they're affordable to build and still have fun racing. You don't need a 150k COPO, Cobra Jet. or Drag Pak to have a nice stocker.
Joe Huestis
Youngsville, NC
Old 07-04-2025, 09:15 AM   #19
james schaechter
Rocky. Two things matter, not conventional wisdom.
1) NHRA hp factor
2) Paul Wong has a lot of altitude 2 bbl stocker runs under his belt. He knows
James Schaechter 3163 STK
Old 07-04-2025, 01:48 PM   #20
BILL TAYLOR
Liked 200 Times in 62 Posts
Originally Posted by Jim Caughlin View Post
I like it but loosen that puppy up, too much clutch.
I don't know about that. Slight bog, no spin, typical rear coil spring twisted wheelie, I'd say that thing is "dialed in" ! LOVE IT!!
BILL TAYLOR is offline   Reply With Quote
