#11 |
Sponsor
Liked 705 Times in 119 Posts
You didn't clarify your estimated amp draw on your car. I had a conversation with Larry Hill about this very subject late last year.
If you're running a carburetor with a stock type coil you can get away with a lot less. I run an EFI system that uses wide band 02 sensors in each primary for data and 2 more in the collectors for the EFI system. Add a EFI High Pressure fuel pump, Large Cooling Fan, electric water pump, 2 Digital Dashes and a Race Pak the little items add way up. Last car we logged years ago didn't have the Race Pak, 02's on primaries or digital dashes. I was drawing 60 to 65 amps during a chassis dyno run. Since I was at Holley when I built this car I opted for the MSD 5361 160 amp alternator. Fuel injection loves Voltage. I also have 2 Optima Red Tops that have worked well. Most times after a run the batteries state of charge is at 95% unless I run the fan and water pump in the pits to cool down. I think that you cannot go wrong by having too much capacity. Good luck! Robin
STK 308 SS 3088 |
#12 | |
Liked 1,019 Times in 367 Posts
Jeff Niceswanger 3740 SS |
#13 | |
Liked 1,789 Times in 408 Posts
Race engines run on gasoline, most of the time. Race CARS run on electricity.
Alan Roehrich 212A G/S |
#14 |
Liked 381 Times in 148 Posts
Thanks for the replies everyone. I am running 6AL and a holley fuel pump as well as dual fans off of something from the junkyard (charger I think?) The waterpump drive is being replaced with an electric water pump. Oh yeah, the big killer, power windows up and down a dozen times trying to keep cool, lol!
Total amp draw? Don't know but I'm always thinking "rather too much and not need it than need it and not have it." (paraphrasing Sun Tzu, lol) Go for eye surgery Monday AM so everything will be on hold for a bit, pull the trigger when I can...or stay with stock alternator with a new belt.....hmmmm....
Jim Miller 103 U/SA |
#15 | |
Liked 7,682 Times in 1,730 Posts
To be clear, what you're building probably won't need a lot of amperage to get it down the track if you have a large, fully charged battery in it. On my old 6 cylinder stuff I would shut off the alternator if I had to go fast but I also was turning off everything but the fuel pump and the ignition box. You're better to have too much and not need it.
#16 | |
Liked 133 Times in 76 Posts
#17 |
I have OO ga wire (I think) to ground on engine block and to the starter solenoid. The factory starter wire going to the starter. Batt in stock location front right of car and alternator wire is factory whatever that is 10-12ga?
Battery is 550CCA and new last year. Edit: Went and took a look and then took a couple pictures. Forgot that the original wiring also includes a plug and significantly smaller wire from Alt to Batt than I thought. Yes, it may be ugly, but at least it's slow....no, wait....lol!
Jim Miller 103 U/SA Last edited by goinbroke2; 07-11-2025 at 02:10 PM. |
#18 |
Liked 10,681 Times in 2,222 Posts
I think the Power Master on line catalog has gage wire and maximum length recommendations. Easy to read and follow.
#19 |
Liked 799 Times in 336 Posts
My son has run a CS130 alternator on his 68 Barracuda drag and drive car for many years and it has worked great for him. I think it was from O'Reilly's
With electric fan, water pump, fuel pumps, ECU and Coil Near Plug Ignition it supports a full load. One of the reasons he chose it was that it came on thousands, if not millions of GM cars and they are easily available at most any auto parts store. |
