Old 01-21-2009, 10:32 AM   #1
big blue galaxie
Default Re: Question on head gasket and oil additive
Get online and get their main number out of Superior, WI and purchase a dealership. That way you can get the oil at dealer cost and save on paying retail for it. www.amsoilsynthetics.com
big blue galaxie is offline   Reply With Quote
Old 01-21-2009, 11:04 AM   #2
Nova4301
Nova4301's Avatar
should I mix the pro blend with the amsoil?
thanks for the info...I got set up with Amsoil synthetics and ordered some.
Tim Wilson HR/SST 4301
Nova4301 is offline   Reply With Quote
Old 01-21-2009, 11:20 AM   #3
big blue galaxie
Absolutely. To me it's the ultimate in protection. I'll give you an example; my wife's daily driver we bought new and after I put some miles on it (about 1500) I switched over to Amsoil and Problended it with the Racing Concentrate. Now it has over 122k on it, oil consumption is about the same and I only have changed the oil and filter 8 times. Saved lots of money these last 5 years with this combo. ProBlend is located in Winston-Salem, NC and get their direct line at the factory.
Old 01-21-2009, 12:37 PM   #4
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
The bore size on a new # 3995633 is 3.980. This gasket was used for the 307 motor,is steel shim & has a coating on it.
As far as I know G.M. has discontinued this gasket.
Not sure of the Fel Pro cross over #.
There are a couple of smaller bore gaskets G.M. # 14085906@ 3.875 & # 462690@ 3.875. They are both steel shim & have no coating on them.Also no longer available.
Just curious,what is the exact bore size of your motor?
Allan
55 Chevy is offline   Reply With Quote
Old 01-21-2009, 02:15 PM   #5
Nova4301
Nova4301's Avatar
Allan
I am building a 307 .060 over. 3.935 is my bore size, so that GM #3995633 would be perfect, but if it is not avaliable then I will have to find a gasket with similar specs.
In case anyone is curious, I found the Fel-pro replacement head gasket for the 307 GM#3995633. It is a Fel-Pro #7733SH1 and it is the same except the bore size is 4.100.
Myron, do you run the 0W-30? and how does the Amsoil racing oil compare...I didn't see a 0W-30 racing oil?
Old 01-21-2009, 09:31 PM   #6
Cometic will make gaskets for you, to your specifications. They are certainly pricey, as much as $200 for a set. But if you are careful, you can reuse them 2-3 times, or more. If you give them a bore size and a thickness, they'll be close to dead on. Mine have not varied more than 0.005" on bore size (always big, not small) and no more than 0.002" on thickness (always thick, not thin).
Old 01-21-2009, 09:50 PM   #7
big blue galaxie
The motor oil is now named Amsoil Signature Series 0W30. The also have a 0W20.
Old 01-21-2009, 09:53 PM   #8
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Castrol also frowns on using any additives with their oil. As the rep stated " why undo something that our chemists have engineered into our oil ?"
Old 01-25-2009, 02:08 AM   #9
House of Darts
Mobil/ Mobil 1 makes the base oils for all synthetic oils. I used to sell race oils. When you read the specs for synthetic motor oil and compare them all, this is what you will find: everyone has a hard one for additives that makes their oil different. When you look very close, many are only slightly different competitors to Mobil 1. They really only offer slight advantages. Most are only noticeable in lab reports. SAVE YOUR MONEY. Brad penn 0-30,10-30 semi synthetic and Valvolone VR1 are the best for the $ spent. Amsoil does offer a oil analisys that will answer any questions about the oil you are using. They contract with a private company. You can deal with this company direct. OH BY THE WAY, ask 50 racers about oil and you'll get 53 answers.
House of Darts is offline   Reply With Quote
