Old 01-29-2009, 09:58 PM   #9
Bub Whitaker
Default Re: Best builder of Carter Thermoquads ?
Originally Posted by aspen7709 View Post
Steve Wann is good with TQ's. Angelo Phillips and I have been doing our own based on Steves original blueprint and have had good success.Jack Foshee is also really good with them also.we do away with the metering rod setup and run holley jets and a few other tricks.Right now we are testing to see wether the side inlet or the bottom inlet is better for fuel feed. and we have been using -6 line with a bypass system.Also use a good air cleaner.my company sells a single 4 copy of the fresh air style unit the works killer.
now were talkin.. sounds like most u guys are doin your own and it sounds like your getting a handle on it. JC need to get with you guys and do his own also... Jim Storms, do you do your own? since you have Stock and Superstock using Thermoquad?
Bub Whitaker
Bub Whitaker is offline   Reply With Quote
