Liked 3 Times in 2 Posts
Anyone put a big block in a Fox Body Mustang?, I have a 577" aluminum headed motor that should make 750hp or better that I want to put in my 90 Mustnag. I was wandering if the extra front end wieght makes the car looser on the top end or dont you feel any differance.
The car is a stock suspention, 12 point caged car, with the small block wieghs in at 2800#, running 28x10.5 M/T's on the rear or sometimes switch to the 325-50-15 DR. I will be putting a glide in the car with the big block... Any help is greatly appreciated.
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
Go to http://www.hardcore50.com/index.htm It is a Fox racing site, lots of guys there have big blocks in foxes. I am sure they can give you good advice. the main page has not been updated for a couple of years but the discussion forum is alive and well.
Direct to forum - http://bbs.hardcore50.com/vbulletin/ Last edited by John Quinn; 01-13-2009 at 01:08 PM. |
It should not be a issue if the suspension is set up correctly. We put a 460 in my son's 85 Mustang
for SS/T and it handles like a dream.Also go to 460ford.com and you will find ALL the info you are looking for on the chassis or engine or anything else. Doug Wesler |
Thanks for the info, I have been on 460.com, and got little to no information there.
How much did you guys do to the 460 to run S/ST?
Freddie - you have a PM !!!
Liked 70 Times in 29 Posts
why not put a stroker small block in there?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Primarily because I already have the big block ,and dont have alot alot of small block stuff
Liked 14 Times in 11 Posts
You might want to contact Mike Graham over on the Stock/Superstock
section of this message board. He runs a 2000 Cobra Mustang with a 460 motor in SSGT. He lives in AZ. Or you can PM me and I'll send you his email address.
Phil Saran Parker, Colorado |
Thanks a bunch guys, you have been most helpfull.
I have found most of what I need, just need to get the whole thing together now, stinks that I will miss most of this season too, but the car will finally be done and running what I wanted it to from the begining. I ended up with a 557 cu. A-Headed motor, that I plan on running my glide behind. The car is all "Stock" suspension and should be a blast to drive. "If" everything works out I should be fast enough to try my hand at S/G, should be fun on a 10.5" tire.
![]() mustang with a bbc 632 twin turbo, drag radials, stock suspension only bolt on aids, no wheelie bars. 6.93@207 after a 7.05@223
Gary Federico S/St, S/G 1814 |
