Old 02-19-2009, 08:06 PM   #5
Bob Alberty Jr.
Default Re: 1150 dominator Questions
This carb is a 7320,box stock calls for 95's squared,no powervalves.
I left the plugs out of the throttle body,(behind the power valve plugs)left the bolts and nuts that were in the secondary blades on the bench,sqaured the jetting at 98 (it's all i had on hand to make it square) I will get the 95's before I go out,and plugged both sides instead of power valves.
Started it tonight and got it warm,ended up with the A/F mixture adjustments out 1.5 turns each ( 4 corner ),which gave me the highest vacuume reading at 5 inches.
The throttle blades are pretty tight as I can not get a .004 feeler guage between the blades and the walls of the throttle body,which leads me to believe it is breathing through the .125 holes in the blades.
The idle varies from 1400 to 1100.To elaborate,if you whack it,after it comes down it is high,give it a few minutes and it drops,but it doesnt just come down clean,but idles pretty good once it does get down.
Thank you for your input,it still isnt perfect,but I do feel like I am closer than I was last year.
Bob Alberty Jr. is offline   Reply With Quote
